Arrigotti
I got my 2 1176's all stuffed and wired, fired it up and had no smoke.
So far so good.
I went to check voltages and found that I only had about 20volts at the first filter cap. I then checked the AC coming from the PT and measured about 15volts.
I ordered the PT that is listed on the North American Part list: POWER SUPPLY TRANSFORMER 2X24V/500mA TE62052-ND
I think that either the part number is incorrect, has changed, or I am hooking up the secondaries incorrectly. I hooked the secondaries up in series as per the data sheet, and took the output across the outer legs. I also made a center tap from the middle legs of the secondaries and connected that to ground.
Has anyone used this transformer? Any ideas where I am going wrong?
Thanks.
So far so good.
Thanks.
