Ian MacGregor
I see op-amps used all the time for unbalancing (at the input) and balancing (at the output) in pro-studio gear. Usually the op-amps are running at unity gain, so what's to stop someone from tossing in a 1:1 transformer to replace the op amp? I have a feeling it's got something to do with the impedence of the op-amp output right? The op-amp has got a super low output impedence, while a 1:1 xformer will have a secondary impedence that is the same as what it sees at it's primary right? So would one need to replace an un-balancing op amp with a xformer AND a unity gain op amp??
