closest 1176 style 500 module kit ?
Winnipeg Mb Canada
A friend wants a couple  , in kit form to save money
Opinions ?  tia
[ He probably wants the black transformer class A output style , as he has one of the
new U.A.  6176  models that he uses  ]
right , this same fellow bought a couple of the sound skulpter neve modules which I put together
and quality & sound was Excellent !
silly question, but how would you get the necessary rails?
I guess you could float the ground and that would give you a 30v swing - but I don't fully understand this myself so I don't know if this would even work. Then what abut then how bout the -10v?
The 500 rack has +/- 15V which makes 30V available.
Set your ground at -9V, easy when you have input and output transformers, and you get 24V between ground and V+.
Pretty simple.
ramshakles is working on selling these shortly
all of Igor's 500 series projects
