The Imperial system used in the USA is pretty screwy. I'm finding one aspect of the system particularly hard to deal with. I would like to make some threaded studs. A rod with threads at each end.
The problem I am finding is that rod stock is available in fractional inch increments. Standard screw diameters are generally written in decimal inch and don't correspond to even fractional inches. As far as I can tell the only screw sizes that match up with available rod stock in fractional inches are a #5 screw at 1/8" and a 1/4" or #12 screw. I don't believe I've ever seen a #5 screw in person. They are rarely used. #4, #6, #8 #10 are much more common. I guess I could start using #5 screws but I'd much rather find rod stock that matches #4 and #6, #8 and #10 screws.
Any ideas?
Any ideas?
