living sounds
Sort of a noob question:
I've got a beautiful sounding made in USA Rhodes Chroma Polaris (also recaped and slightly modified by me). It's got a high amplitude output, pretty much the loudest synth in my studio. The output stage (schematics below) has a 100 ohm resistor in series to counter capacitance of longer cables.
The problem is that going into my console (with the synth ground connection going to the console's inverting input and the console ground floating) with a 7m cable, transients and signal clarity are significantly worse than with a 2m cable. I cannot measure cable capacitance, but the resistance is pretty much zero ohm. Also, there is no audible interference, the noise floor is no different between cables.
So what am I missing here? And what to do? Thanks!
