sharpeleven
PCB's received. thanks!
kambo
PCB's received :)
cheers
kambo
suli
Hi
PCB's received
cheers
Suli
Suli
In for MK-U47 PCB.
In for 1 MK-U47 PCB
stelin
In for 2 MK-U47 PCB.
vinylwall
I would like 2 MK47 PSU boards as well.  Jimi Ray
Jimi Ray
zayance
Hi There,
I have stock for the MK47 version (Polar Pattern on PCB)
But no stock left for the MK-U47 (Polar pattern on Mic)
Wich one were you interested on (I ask because sometimes people get confused)
T.
vinylwall
Hi There,
T.
It is the MK47 with the patter on PSU.
Jimi Ray
morbleu
In for 1 MK-U47 PCB
Andreas
vinylwall
Hey Tony.  Are you getting close to running more MK-U47 (non-pattern switching) boards?  I'll be needing one soon.  Thanks.  Jimi Ray
Jimi Ray
Category 5
You know the green boards will also work for the MK-U47 too.  you can just leave the pattern selection compnents out if you like (or don't - Just don't connect the pattern terminal to the XLR/Binder).
That said, I'd be in for 4 more if you're polling.  Seems none of the other 47 PSUs that have been announced are surfacing anytime soon so your board is the favorite.  The black looks cooler!  How about a universal version?  The green board done in black, with the black boards slick looks!  Then, populate what you need.
I'll commit to some of those.
vinylwall
Category 5,  looks like with your 4 PCBs, that gives Tony another 10 of the MK-U47 version to run :)  And thanks for the advice on just leaving the pattern selection items out of the MK-47 version.  I'll wait to see if Tony is going to run more of the MK-U47 version.
Jimi Ray
zayance
Hi There,
I'll order some MK-U47 Soon.
Thanks a lot, Keep in touch.
T.
PCB's received ,thanks  8)
what are people using for the trim pot?  mouser only sells them by the thousand and they dont have anything similar.
thanks
Category 5
thanks
http://www.mouser.com/Search/ProductDetail.aspx?R=026TB32R102B1A1virtualkey67110000virtualkey774-026TB32R102B1A1
thanks cat
is there a build thread, or does someone have a pic of a completed unit for the mk47 psu. im having a hard time figuring this one out
Category 5
