Moved from Portable Preamp Thread.
With respect to RTS-1400 (schematic attached) I was really just looking for specs on the frost output transformer.
There is nothing online.
They all seem to have Beyer or Jensen input trafo's and they ALL seem to have Frost output transformers.
I put the full Technical Manual in the Technical Documents section:
http://www.groupdiy.com/index.php?topic=53073.msg677365#msg677365Anyway, I bought a couple of dozen of those RTS preamps a few years ago for $10 each. The frost magnetics transformer in them is unspec'ed on the internet. I bought them for the parts (nice little box, and two nice transformers in each).
I use 1 that I keep in my portable toolbox, but rarely need it. The rest I use as a source of transformers, connectors, etc for other projects (I built a couple of ssl 9K's with all the 5532's). Most of them had Beyerdynamic 1:10 7 pin PCB mount shielded studio transformers for inputs and Frost for outputs. A couple had Jensen 1:8 input transformers (JE number not JT whatever that means).
Anyway in my test the Frost outputs seem to work well (quadfilar wound #32 wire about 400+ turns on a EI lam ) but only with low impedance transistor drive (too much interwinding capacitance). It is wound similar to a JT-123slpc but has much lower inductance (jensen 9.43 henries, frost I think a little less than 1) I assume the core is steel vs 50% nickel for the jensen.
The beyer I have used on tube preamps with success.
Anyway I was looking for projects (ideas welcome) that could consume these many frost trafo's (I have made a reamp box, some transistor preamps, and tried re-winding a couple with little success.
