Thanks, that's really informative. I'll read it a few more times to make sure I'm understanding it better.
A few questions I have, if you don't mind taking the time:
PRR said:
The "200r" winding has about 20 ohms of copper resistance. If we use it in a 100 ohm circuit, it works, with perhaps 20% loss. If we work it in a 20 ohm circuit, half the precious signal is wasted. OTOH it has a shunt impedance perhaps 2K (more likely 1K at the band limits and >10K midrange). If we used it in a 1K circuit half the power is wasted (perhaps worse: big loss at 20Kz and 20KHz but low loss at 1K, a humpy response).
OK, so to make sure I'm understanding right: the primary winding has about 20 ohms of resistance-- this much is fixed and is always a component of the impedance "seen" by the microphone, correct?
Due to Ohm's Law, the impedance ratio (from primary to secondary) is 1:49-- the transformer's voltage ratio is 1:7, and its current ratio is 7:1. Impedance equals voltage divided by current. 7÷(1÷7) = 49. So the impedance seen on the primary side of the input Tx would be [(impedance on secondary) ÷ 49]+20. Am I on the right track?
I'm not sure yet how to figure out the input impedance of an EF86, but if I had that number, I could figure out the
actual impedance reflected back to the mic, correct? And if that number is higher than about 10k, the actual impedance seen by the mic will be more than 200R. Correct? And this will vary somewhat with frequency too, right?
One thing that I'm not sure I understand yet is where the 2k "shunt impedance" number comes from. I'm googling, and learning, so I'll keep working on it. Compared to most people here, my understanding of certain things is still very basic.
So your "200r" should be fed from a 100r-400r source. This covers most mikes. [size=8pt](The odd 50r powered condenser mike is so hot that loss or noise-resistance is unimportant.) (This will not be the best choice for old-old RCA mikes wired 37 ohms.)
I think I'm a little lost by this point. Wouldn't a 400r source want to see about 4k input impedance for maximum voltage transfer? Is the "200r" transformer winding actually showing it that much? I just want to make sure I understand. This would imply that the secondary of the input transformer was seeing about 200k from the EF86. At 100k or above, it would at least give you a solid 5x the 400R source impedance, which is pretty good. Am I missing it?
Thanks again for your time and insight so far.
