Dual concentric grayhill rotary switch/pot combo
« on: July 27, 2013, 09:29:18 PM »
Hi.
I'm trying to find a suitable rotary switch for some eq modules, and I like the idea of te PC mount grayhills, I've tried to find out what grayhills that Neve use in their lunchbox eq, but can't find it. Wondering if this is a custom part.
They are rotary switch on the outside and potentiometers on the Inside, of a dual concentric switch, correct?  Curious if anyone knows the part for these, so that I can research, or something similar, doesn't have to be pcb mount I guess, but I like the idea..
Any help would be greatly appreciated.
S
« Last Edit: July 28, 2013, 12:13:57 AM by Fuccimain »
helterbelter
Re: Dual concentric grayhill rotary switch/pot combo New
« Reply #1 on: July 28, 2013, 03:36:19 AM »
The switch is a Grayhill with a hollow tube shaft, the pot is made by sfernice.  I haven't seen the grayhills in this format, but I have seen dual concentric switches for sale. You can de-mount the inner switch IIRC.
Hope that helps....
Oh, by the way, I have a load of dual concentric pots leftover, 10pcs 2x 22kC/10Klog, and 10pcs of 22Klog/10Klog IIRC. Maybe they can be of use to you ?
greetings,
Paul
« Last Edit: July 29, 2013, 02:45:04 PM by helterbelter »
bigugly
« Reply #2 on: July 28, 2013, 10:02:55 AM »
Hollow shaft Grayhill switches are a custom order part. You can order them with single or multiple decks. Give them a call. They are pretty helpful.
http://www.grayhill.com/products/rotary-switches/
"...the land of the free*, and the home of the brave"
*some restrictions may apply, see Congress for details
Last post August 09, 2008, 04:41:51 PM
by Bluzzi
Last post May 12, 2009, 08:24:32 PM
by pucho812
Last post February 26, 2019, 07:43:29 PM
by pucho812
Last post November 13, 2020, 05:22:43 AM
by beatnik
