Grubbalot
Member
Suppose I had a circuit like NYDave's "simple tube preamp/lineamp", currently found a few threads lower on this page. How would I go about implementing a mute feature in there? I'm thinking something along the lines of a mute that you could trigger with a pedal on stage, for sending to a tuner, or generally anything that doesn't involve some kind of sh!tty switch between the guitar and the amp. Could you just add a small active switch somewhere before the last tube stage that would send the plate straight to ground? Or would that cause pandemonium?
