Summing mixer/make up gain idea
Humner
Sydney Australia
I don't have a deep understanding of this, so hopefully this idea doesn't make me look silly  ;D
Could this work?
Passive summing 8 channels into 2 channels which go to a 300:2k7 Tamura transformer > unbalanced makeup gain circuit > 600:600 Tamura transformer to make it balanced again on the output.
Would this work? Could I use/modify a simple mosfet booster circuit -  http://www.muzique.com/schem/mosfet.htm - as make up gain?
Yes, this is a common approach. The 300:2K7 transformer gives a useful almost noiseless gain and provided the unbalanced gain make up has a good noise figure, enough gain and an adequate drive capability you should be able to strap 600:600 transformer across the output to balance it.
Unfortunately, the little FET booster you linked to does not meet all of these requirements.
ruffrecords said:
Humner said:
Thanks for getting back to me.
Probably best going with a 312 style circuit for the make up gain?
Pass. What's a 312?
Probably an API style gain stage, but 312 is a mic pre... He's probably thinking in a 325 line amp.
JS
I'm not familiar with the API model numbers but 8 input passive sum needs make up gain of at least 8x so if line input has that much gain trim it could work, mic pre would accommodate summing even more stems.
325 is basically the 312 mic pre without the transformer, but he want to add a transformer so it's the mic pre... depends on how you draw it, transformer inside/outside...
JS
say I take the circuit of the Access 312 - http://www.groupdiy.com/index.php?topic=46362.0
I wouldn't need 48v, phase or other additions, just the main gain stage between the transformers.
I have to admit that because you said it was a passive summing mixer I ASSumed you have balanced inputs and that is the reason for the transformer. Even with balanced inputs you don't have to use a transformer. However, if you use a transformer designed for a 300 ohm input then you will have to slug the bus to match this impedance so you will need more make up gain than the 8X that John mentioned.
So, a little more detail about the application would be handy.
So ... what do you WANT?
An opamp based make-up for your transformer-based mixer?
Or do you want a deliciously crusty MOSFET gain stage that will considerably warm-up your precious tone - while also considerably warming up the surroundings? You know, pure Class-A. Almost like a real valve ...
Decisions, decisions, eh?
Look up "Bride of Zen" and "Moosefet". Google, of course.
Read, study, learn.
P.s. To get close to the "8x" makeup gain as JR suggested, you will have to mod the source and drain resistors values, f.e. 100R and 820R in BoZ.
I just noticed this thread - http://www.groupdiy.com/index.php?topic=52068.0
So I now want one of those boards(Ian I have sent you an email, hopefully you have some left) - and there is a nice guide to calculating resistor values.
Hi TV,
I'm just after a simple make up gain circuit to fit between 300:2k7 Input and 600:600 output transformers(just because I have them lying around).
Can be Opamp, DOA, fet, transistor based. Not fussed, just after a simple design. Thanks for those ideas, I will check them out. However looking at ian's db25 summing board thread, maybe going the Access 312 mic preamp design and "slugging" my buss channels might be the way to go.
Ian, that's right, you have assumed correctly. I'm going through your resistor values guide, and its very helpful(along with your post).
Ah-hah ... if so, I suggest that you go with an existing design, if possible available as a kit, with good support/troubleshooting docs.
Even though BoZ et al. are afaik also available in kit forms, I think those mosfets are a little hard to tame if you haven't tickled them before... especially if you plan to transformer-couple the damn thing.
