Headphone Amp (Head Grinder)
« on: August 23, 2013, 02:32:18 PM »
I made this headphone amp based on an original schematic from Jakob/Gyraf.
And heres a documen you can use for self etch purposes (unless I did something wrong with the output).
https://pcbgrinder.com/download/HG_docu.pdf
Thats all...  :P
Gustav
« Last Edit: August 24, 2013, 05:43:15 AM by Gustav »
ruairioflaherty
Re: Headphone Amp
« Reply #1 on: August 23, 2013, 02:49:32 PM »
Love the funky chassis Gustav!
elskardio
Re: Headphone Amp (Head Grinder)
« Reply #2 on: January 25, 2014, 12:01:22 PM »
Hi Gustav,
since the input is not balanced, how does it performs over long cable runs? I have 50' of snake between the control room and my booth.
rob_gould
« Reply #3 on: February 05, 2014, 04:26:28 PM »
I'm trying to build this on perfboard and I just want to run a couple of things by you all since I'm not sure...
I have built the entire circuit except for the potentiometers R17 A and B and the caps C7 and C9 because these'll be off the board.  I'm going to put it into a 51X rack so I'll be using the + / - 16V rails for power.
I just checked my voltages with the NE5534 removed from the circuit, and at pin 4 of the NE5534 socket I get -16V so that is perfect.  But at pin 7 where I was expecting to see +16V or thereabouts, I get -14.9V.
How can this +16V invert in the circuit to give -14.9V?  I've tried to work through this circuit as well as my limited knowledge allows, and I just can't see why the +16V is getting inverted.
I've checked the voltages going into the circuit and they are correct, so it's definitely a problem in the circuit and not from the PSU...
Any ideas anyone?  My only thought is that the BD139 and BC140 I have do not have the same pin out, so the BD139 is the wrong way round.  Could that cause this issue?
Studio furniture, modular synth cases and more...
www.gouldcaseworks.nl
Harpo
« Reply #4 on: February 05, 2014, 05:12:29 PM »
...My only thought is that the BD139 and BC140 I have do not have the same pin out, so the BD139 is the wrong way round...
There is no BC140 (NPN transistor) in this circuit. You want a BD140 (PNP transistor) and beside this, the case and pinout differs as well.
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.  -Douglas Adams
rob_gould
« Reply #5 on: February 05, 2014, 05:32:19 PM »
Sorry, that's a mis-type rather than an error in the parts I've used. I definitely have BD139 and BD140
rob_gould
« Reply #6 on: February 06, 2014, 04:16:16 AM »
Found the error...  +16V rail was not making good contact with the PSU connector.  As soon as I sorted that, it came good.
sharpeleven
« Reply #7 on: March 23, 2014, 05:01:21 AM »
How did that end up working out for you in the 51X format? I was thinking of doing the same... any insights? Thanks!
rob_gould
« Reply #8 on: March 23, 2014, 05:51:17 AM »
It took some work because I made 3 x headphone amps with a debalancing circuit and distribution amplifier based on (read shamelessly copied from) this thread
http://groupdiy.com/index.php?topic=53523.0
I needed to add build out resistors and I skipped the first amp section of the TL074 but after some experimenting it works very nicely.
So yes, I recommend this circuit. It was a good learning experience for me and it sounds good.
