Axelerator
Hi, i have moved in a new house and my homestudio will be set up in the attic. the place is 4,80 m *5.10 , minimal height is 120 cm at the sides with A shaped roof (45 degrees).
normaly i would say i will face one of the the walls with the roof to the sides. that would be the side which is 4.80 so alittle bit shorter. But the bigger problem is that one half of the side wall is a big window from ground to top, the other half is concrete wall. the opposing side has the same problem but inverted... so i would expect crazy imaging in the upper lows.
right now i am facing one of the sloped roof walls, this way i have quite ok imaging even without a lot of acoustic treatment. i have some flutter echos which will be treated quite easy i hope.
I want to make the slope roof more or less ´dead´with some cloud over my place.
i did not measure yet but i think i have no bass problems,due to plasterboard roof with thick isolation(50 cm !) and the two big windows.
disadvantage is that my monitors can not fill my room anymore, so i want to get new ones. thinking of some quested v3110 as mains. i would have to place them at the wall what means that they will be directly under the beginning of the roof shape (hope that makes sense..). as i would cover the space above the monitors with acoustik treatment i fear iwill have reflexions in the lower regions . (with a fast reflexion from above and a later one from the ground )
my question is if maybe the main monitor solution is not as good in this place and i should go the smaller monitor- with -sub(2 sub´s) route.i did not like sub´s for mixing yet..
i know i should hear the monitors in my place but lifting around 40 kg´s and get them shipped(ship them back is a major pita so i would like to sort out some no-go´s if there are any.
long post, but if anybody has some experience with attic studios please chime in for some hints !
greets
axel
greets
axel
