Hello, sorry for the necro post but Ive been having the same issue. I finally found this to be the most relavent thread & hate starting new ones when theres already a good thread going.
I’d love to build a whole new linear PSU as mentioned above but its a bit pricey for me right now. Ive found that the Noctua NF-A8 FLX 80mm works amazingly.
I had to drill out the unused holes in the back side of the fan to get the screwdriver through for mounting & couldn't use Noctua’s rubber chassis mounts as the fan mounts directly into the heatsink. I used their corner grommets & should have used a lil silicone grommet between the screw & the fan body but I didnt have anything. Its still extremely quiet. The only time I heard the fan was during testing when I left the fan unplugged to heat up, then plugged it back in. It was a dull hiss w chassis open in front of me; still NOTHING compared to the weedwhacker I pulled out of the thing.
Again, I’d love to build a whole new PSU but for now, this thing works wonders & is completely inaudible during typical use on my 32ch w/ CAL mod.
It’s a cheap alternative. Not sure if quiet fan tech was as good back when this thread was new but this particular fan is a very effective bandaid.
Hope this helps!
—————-Update—————-
Now that its buttoned up & in the rack, the fan is still completely inaudible but when its dead silent in the room, you CAN just barely hear the air passing through the holes in the front of the chassis once the thing gets going. Less than the AC vent but still, just a bit. Absolutely fine for mixing but not perfect in a one room studio like mine w mics & all. Even still, it is a whole HELL of a lot better than what it was before; the old one resonated the rack which this definitely does not.
From an annoying whine to a feint whisper for $20; I’d do it all over again twice.
