radardoug
Re: Apex 460 Noise
« Reply #40 on: March 04, 2019, 06:33:00 PM »
So how much ripple did you see on the scope?
bernatvm
Re: Apex 460 Noise
« Reply #41 on: March 04, 2019, 07:00:02 PM »
I think this is normal ripple for a good PSU
I went to the lab earlier today and took at the voltages where the cable join the mic pcb with the oscilloscope. Didn't have time for any of the other tests. Here are some pics of the readings, I think there are no problems.
Heater
B+
I also attach an FFT of the noise. Snapshot is taken in a silence moment on a speech track. The gain is what I would usually use in that situation.
radardoug
Re: Apex 460 Noise
« Reply #42 on: March 04, 2019, 09:59:17 PM »
You shouldn't be able to see any ripple.
bernatvm
Re: Apex 460 Noise
« Reply #43 on: March 05, 2019, 02:28:00 AM »
Even at that scale? Those pics are taken at 10mV/division
bernatvm
Re: Apex 460 Noise
« Reply #44 on: March 05, 2019, 03:01:30 AM »
Shorted pin 2 of the to ground and the noise is gone. That makes me think the problem is between the capsule and the tube. Do you agree? What could it be?
JohnRoberts
Re: Apex 460 Noise
« Reply #45 on: March 05, 2019, 10:33:41 AM »
Scope measurements are relative to the ground lead, so check where that is connected?
John Roberts
http://circularscience.com
Tune it, or don't play it...
bernatvm
Re: Apex 460 Noise
« Reply #46 on: March 05, 2019, 10:42:47 AM »
Scope measurements were taken referenced to the chasis of the microphone
radardoug
Re: Apex 460 Noise
« Reply #47 on: March 05, 2019, 02:55:37 PM »
Pin 2 of what? the microphone cable or the output cable?
If pin 2 is a ground, then your problem is fixed.
bernatvm
Re: Apex 460 Noise
« Reply #48 on: March 05, 2019, 02:59:07 PM »
Pin 2 of the tube, sorry. It's signal input from the capsule to the circuit
radardoug
Re: Apex 460 Noise
« Reply #49 on: March 05, 2019, 09:27:25 PM »
Yes, well that will certainly stop the noise. Try disconnecting the capsule and everything but the high value grid resistor. See if it is noisy. Then substitute a 1 meg resistor for the high value resistor. See if it is noisy.
Mylithra
Re: Apex 460 Noise
« Reply #50 on: March 05, 2019, 11:05:22 PM »
You're sure youre not working with a microphonic tube?
Out of curiosity, why'd you pulled the 2 filter caps in the 12v PS?
bernatvm
Re: Apex 460 Noise
« Reply #51 on: March 06, 2019, 02:06:27 AM »
I tried three different tubes all with same results, tube might not be the problem.
About the caps, which ones are you referring? I don't think I pulled any of them in the 6.3V (actually a typo in the psu schematic)
« Last Edit: March 06, 2019, 02:53:43 AM by bernatvm »
Re: Apex 460 Noise
« Reply #52 on: March 06, 2019, 10:54:36 AM »
At the beginning of this thread doug said the ratio of bad tubes to good might be 100:1.
He also said earlier on to sub out the 200M with 1M and see if the noise improves and if it does, it may very well just be that the tube isn't up to the task.
Mylithra
Re: Apex 460 Noise
« Reply #53 on: March 06, 2019, 12:55:54 PM »
In the first post I saw this:
I removed C9 and C10 which act as RF filters.
In the PSU ,these are the larger filter caps in the DC heater supply. Are these not the caps you're referring to?
bernatvm
Re: Apex 460 Noise
« Reply #54 on: March 06, 2019, 01:00:36 PM »
I was reffering to C9 and C10 on the microphone, filters on the transformer output.
bernatvm
Re: Apex 460 Noise
« Reply #55 on: March 07, 2019, 05:14:36 AM »
I tried the 1M resistor. What I got was the expected hpf on the signal, but the noise was still the same and went down to the sub area at a very similar level than before.
Re: Apex 460 Noise
« Reply #56 on: March 07, 2019, 02:08:51 PM »
Did you ever resolve the pin 7 and 4 grounding problem? As in make sure that they're at the low measurable limit of your ohmmeter with the new cable?
Have you measured the resistance of the head basket to other parts of the mic body itself? Could it be possible that the headbasket or mic body isn't quite as conductive as it should be? Try wrapping the whole thing in tin foil lol.
Try measuring a wire and making sure it reads that same as your probes shorted, attach it to PSU ground and touch the other side straight to the mic. You might get some sort of hum obviously but like it's worth it to see if the noise goes away.
Just some ideas.
EDIT: Also, why not try throwing those RF filter caps back on? Maybe something is heterodyning?
« Last Edit: March 07, 2019, 02:16:15 PM by davemascera »
