I thought I would prototype a card (2 cards actually) to allow connecting a 51x module to the next module in the 51x rack. To keep the signal path short, and the wiring easy, I did it with relays. The whole card fits in the space under the XLR connections (just like my TASCAM adapter ... It is the same size). I have to lay it out again because I want to use standoffs and the holes in the 51x backplane (Or I could mount this one with standoffs off the metal back). (By the way.. does anyone know (Volker) if all the versions of the 51x Rack backplane use the same hole spacing? The holes are never used, so I am worried about them going away).
Anyway it works, and it is kind of cute.
Uses +16V for the 12V relays, but uses -24V for the LED's because there is lots of -24V unused). I am putting this one into my 8 channel meter so I am only using 7 switches and relays (because there are only 8 modules when I fill three slots with a meter) but it is capable of routing 9 modules to the next module (1-out to 2-in, 2-out to 3-in, etc... finally 9 out to 10 in.) and the switch card will fit vertically in a single module so a simple 1 module switch front is possible (in slot 11).
So it can do this simple switch front plate (might need studs on back of the faceplate - or screws to hold the carrier)
The relay card fits in the same place that the tascam adapter does (the left one probably).
And I am trying to fit the switch board into the front of the this meter module, with a button under each of the left hand 7 meters. I am trying to mount it with standoffs off the metal case, but I may have to resort to toggle switches (which fit in the same card).
There is a 500 series rack out there where they have switches on the back to do this, but I liked the idea of being able to assemble a preamp and a couple of effects (eg EQ and compressor) on the fly, from the front.
