hi, i have a calibration problem with my hairball REV G compressor.
I did the calibration step by step like its written in this calibration manual:
http://www.masonaudio.org/ma_files/G1176_Calibration.pdf
Q bias : OK
Dist. Trim : OK
GR Meter Zero: OK
GR Meter Tracking: Problem!!!
I put a 1 kHz, 50mV signal, Set the input level 12oclock and set output level to the same 50mV signal like the input.
Than I switched to GR mode. and turned up the level of my input signal at the signal source...
both input and ouput signals are increasing 1:1... so if I turned up the INput signal at the source, the Input and the Output signal was always at the same value... no 6dB gain reduction!!! I tried to trim the tracking ADJ R54 on PCB, only 2db result on the VU - Meter...
I tried to put in a audio signal, no Reduction, no compression,...
maybe I did something wrong but I can`t find the problem on the PCB or on the wiring...
Can someone help me? Anyone heart about this problem allready???
thankfully!
twhanny
Q bias : OK
Dist. Trim : OK
GR Meter Zero: OK
thankfully!
twhanny
