Hello folks,
I've been busy this thanksgiving holiday putting together a shopping list of parts required to build a 4ch Eden system, with the sleek digital relay control etc.
All in all, the total system cost including supplies from Expat Audio, Mouser, Antek and Par-Metal sits in the range of $600 for 4 channels.
I considered buying the mouser parts into expat audio inventory, and then reselling them, but frankly, I'd be buying them at not much less than the price you would be. Then I'd have to mark them up to make it worth my while etc. That would likely increase the cost of build!
I've attached an excel file with bill of materials.I believe it's 100%, but right now, the systems I've build have been built up from existing inventory I already have.
Mouser's inventory carries almost everything at a reasonable price. I found some components much cheaper to source from Amazon. The transformer and case need to come from Antek and Par Metal (or Collectivecases.com)
I've also updated some of the documentation available, to make things easier.
Eden Board Users Guide: http://expataudio.com/diy/edenmicpre/Eden%20Microphone%20Preamplifier%20PG20.pdf
Schematic for the Eden: http://expataudio.com/diy/edenmicpre/ina163pre-layout2%20-%20PG2.1-sch.pdf
Footprints for each board used, to be used for floorplanning inside your case: http://expataudio.com/diy/edenmicpre/Edensystemfootprints.pdf
Bill of Materials for the system: http://expataudio.com/diy/edenmicpre/System%20Cost%20-%20External.xlsx
(this has not been 100% verified)
Sub Board Documentation
Uber PSU Users Guide http://expataudio.com/diy/uberpsu/Expat%20Audio%20Uber-Power%20Supply.pdf
Mic Pre Front End Users Guide http://expataudio.com/diy/DCMicFE/Mic%20Front%20End%20Manual.pdf
3button Controller Users Guide http://expataudio.com/diy/3btncntrlbd/Digital%20Control%20Board%20Build%20Manual%20v2.pdf
Also, please note that Dan at CollectiveCases.com will be releasing an enclosure any day now that will fit this beautifully!
http://www.collectivecases.com/PDF/1U-EXPAT-EDEN.jpg
8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
8) 8) 8) 8)Stay tuned for Holiday bundle deals on the Expat Audio parts needed! 8) 8) 8) 8)
/R
/R
