Basic 11 slot 500 and 51x module racks
served
***Currently OUT OF STOCK!!***
Current version: Rev 3
Rack can take 500 or 51x modules.
It has space for 11 modules.
IO
Input and Output is standard XLR.
Ground lift with jumpers
Stereolink with jumpers.
Power Supply
PSU is standalone and not inside the rack, to reduce noise and heat problems.
All the voltages can be readjusted if needed. This PSU is capable of powering two 500 racks if correctly configured.
Outputs: 1.5A per rail.
Cable length 2m (or longer if needed)
PSU will output 5 different voltage.
Voltages are set to 51x standard:
+V1: 24V
-V1: -24V
+V2: 16V
-V2: -16V
+48V phantom
To ensure a long life:
PSU utilizes a powerful 250VA Toroidal transformer.
All the heat is placed away from the filtering caps straight on the heater.
Added extra support for the rack PCB to prevent any physical damage
Price is 500€ for PSU and rack with 11 black faceplates and screws.
They are brand new!
Fully assembled.
Shipping worldwide.
Accept  paypal or Bank transfers.
Free service 1 year.
http://www.vandaal-electronics.com/
https://www.facebook.com/VanDaalElectronics
Hei Gustav!
Thanks for your kind words!
Racks are made of steel. Painted with powder and printed with silk.
Hi.
The first patch is built for 230VAC mains.
And it currently can not be modifyed.
I could make an exception and change the transformers inside the PSU for 115VAC Mainsvoltage if needed.
But the PSU frontpanel will stay the same.
I could have a 115VAC version in 5 days once you have decided if you want it.
Ardi.
hello,
I would also be interested in the rack case without the PSU...
what would be the price?
Hi.
Well Ian only wanted the metal part of the rack. No PCB and other stuff.
Currently I can't sell metal jet. I would like to sell the first patch.
There is only 3 Racks left.
If they are sold, I will order new patch and you can write down your wishes and I will contact you once I start a new run.
But if adrian likes to get complete rack fithout PSU and electrisizer would like to get a PSU only, then you can split the price the way you can agree and I will be satisfyed! Then I will just shipp them to separate location.
About shipping.
The package weights 12kg
When using our local post office service, with tracking, it will cost about 50 eur to shipp to USA
For europe, its a bit cheaper.
When using DPD for europe.
The price varies from 22 to 50 eur depending on your location.
I will give you separate price calc for rack and PSU.
OK,
electrisizer have to wait so if someone else is interested in a PSU I will take the rack... let me know!
Rack price is 300€
With Power connector male and female. You can make your own cable.
11 faceplates.
PSU price is 310€
With cable and selected power connector if available.
115VAC version is now available.
Going to launch a Rack mount PSU in a near future. With enough power for 22 modules or more.
Well see...
How to connect two racks to the psu?
Well see...
Great!  :D
In this psu, two or more connectors for racks?
I have some BAE enclosures without psu. I think the rack mount psu will work well with your lunchbox and BAE toghether. (Using appropriate cable for BAE)
Well see...
Great!  :D
Its going to have multiple outputs.
There is going to be a discount on the Rack only purchase until Christmas (24 Dec.)
Rack with 11 frontplates and screws plus powerjack.
will cost 270 Eur.
Only 3 racks are available so hurry!
