soo im killing myself trying to figure this one out...
This desk is a DCM232.. for those who dont know it is one of those desks that does alot of the "logic switching" from the master section.. things like EQ on/off insert pre post etc...
select the channel and turn on/off the I/O functions from the "cap"
works just fine but... if say I turn on a bunch of functions on a large number of I/O 's everything is ok until I select a channel that has nothing turned on.. when I switch back to a channel with alot of functions turned on theres a quick negative spike on the 12V rail. this "glitch" causes the consoles computer to reset.
Ive tried putting some caps on the 12V rail coming out of the p/s with no success.. I tried putting some caps localy near the area where I believe the problem is occuring with no success.
its a very very quick glitch and it only seems to occur when theres a large load swing on the rail...
very frustrating trying to locate this problem... if I can get this one knocked out the board will be like new :\
