Question 1:
Is it generally "better" practice to keep signal and power grounds separated on the PCB, then bring those out to one ground point in the chassis/earth?
Question 2:
If I wanted to build several devices into several enclosures, and have one power supply (which is housed in a separate enclosure) power them all, what would be the optimal grounding scheme? Would I ground all of them to one point in the Power Supply Enclosure? Or have each device, and the power supply grounded to it's respective enclosure?
Thank you so very much!
Question 2:
