Hey guys,
I just made myself another filament power supply with a 317 regulator. Problem is that it goes into thermal shutdown after about a minute when it feeds a 6N1P heater. The circuit is the standard circuit in the datasheet with protection diodes and the regulator is sitting on a heatsink that looks like this:
I'm using one of those little pads that replaces mica/grease, which must be doing its job, 'cause the heatsink gets HOT!!!
So how much heatsinking do these things need to deliver the full 1.5A on the datasheet? The plastic enclosure I'm using comes with a flat aluminum bottom that's about 7" x 5". Would that be enough if I bolted the regulator to it instead?
Peace,
Al.
Peace,
Al.
