I just went over the whole thing 3 times, re-tinned all solder joints, (*all* of the passive components on the main PCB are identical to the BOM/overlays... I can't find anything wrong?)-
I then pulled all the resistors and caps surrounding the DOA, checked them (all well within range) and put them back in the circuit. (sheesh!...after pulling the 2503 & the passive components this PCB is beginning look a little sorry...)
Anyhow, I put it back in the jig...same thing.... **way hot op amp**!
I did (very quickly) shoot a test tone thru it- it's not passing audio at all (a little "tic" when engaging the EQ-in button, but that's it)
Anybody have any other suggestions? I do have a scope, etc. here. ANYTHING?
I'm just not sure how safe it is to leave the thing powered up while testing it? I'd rather not cook the DOA's (or anything else!)
Thanks Jeff for all the help!
