Hi erol!
They sound "neveish"
larger than life, smooth high end... "warmer"? that´s not the word that would cross my mind here. If anything: "coloured"... not the cleanest unit. But they defiantly give you some "analog" feeling.
Signals run thru or recorded with a good analog pre (like the MP537) are easier to handle during mixing. EQs "grab" the signal and you generally don´t have to put as much procession on it. So i would recommend every (Home)-Recorder or ITB-Workers to invest in a good pair of analog preamps, it will make life a little easier – but that´s only my personal experience...
I have one unit, i use it to record bass, clean electric guitars, acoustic guitars and vocals. i ordered a second unit a few days ago, so i can use them for overheads... two 1073 with ribbon-mics is a great combination or overheads imo.
The rack-unit has an output pot, the 500-version has a trim-pot. i´m not sure, but i think the original 1073 only had a gain-knob...
The output-pad/pot is cool if you want to override your transformers, but that´s something i would likely do more with an 312, not an 1073.
BUT: i have no experience with synths and neve... so, i´m not sure if that´s the sound you are looking for.
BUT 2: sound skulptor pres are very good sounding units, they are cheap for what you get and it´s a lot of fun to build them.
Chris
