C Coldsnow Well-known member Joined Feb 6, 2005 Messages 296 Location Ohio Feb 6, 2005 #1 Can I just use two external wall wart type power supplies (one + - 15V and one + - 12V) for the SSL clone? I am not a professional and don't like messing around with power supplies. Thank you, Great site by the way.
volta Well-known member Joined Dec 10, 2004 Messages 118 Feb 6, 2005 #2 As long as you have enough current coming out of the wall warts it should work fine. Probably not the cleanest choice of power though.
C Coldsnow Well-known member Joined Feb 6, 2005 Messages 296 Location Ohio Feb 6, 2005 #3 Thanks, Any particular amps? Also are the THAT VCA's direct replacements without anything else needing done to the circuit. Thanks again.
mcs Well-known member Joined Jun 4, 2004 Messages 1,017 Location Denmark Feb 6, 2005 #4 You could use a supply similar to the one on this schematic: http://stiftsbogtrykkeriet.dk/~mcs/Phono1_sch.gif You would just need a 15-18V AC wall wart then. Best regards, Mikkel C. Simonsen
