Delta Sigma
Re: Telefunken ELA M 251 Clone Tube Microphone Build Thread (D-Ela M 251E)
« Reply #680 on: February 25, 2020, 04:20:02 PM »
Measured it, it is 3.4 actually. If I am not mistaken I read in one of your posts that you used two 6.8uf 75v in series ( 3.4uf 150v sum). I found two Siemens on eBay with those values so I am gonna give it a try since it looks like a very simple and effective solution. How did that work out for you? Thanks.
Sorry, I didn't do that but I don't see why it wouldn't work. I believe Fender used to do this to get higher voltage filter caps in some amps (CBS era?).
Remember, as long as you're being safe and not exceeding the ratings of components,  do what you can to set up a good comparison. The only thing that I'll add is that you should record before and after each change, listen back, wait a day, then give it another listen. I've made a decision on a component swap, then listened back to the recordings later only to find that I'd changed my mind.
Some people prefer to test component changes with instruments that have a wide frequency content and some prefer to use their voice because you know you're own voice well. I do the latter.
« Reply #681 on: February 25, 2020, 05:30:45 PM »
Thanks, yes I try to keep track haha...I have a bunch of messy test sessions. Voice and acoustic guitar usually tell me a lot about a mic.
« Reply #682 on: March 25, 2020, 07:21:16 PM »
Hello electron wizards. I started my d251 build and I am a little stuck. I finished the psu but I don’t get any reading on the B+ ( on the screw green pad). I am including some pics of the wiring in case I did something stupid. Thanks guys.
« Reply #683 on: March 25, 2020, 07:24:02 PM »
And one more
Delta Sigma
« Reply #684 on: March 25, 2020, 11:03:24 PM »
Check voltages on both sides of R1 & R2 and the B+ side of R4.
« Reply #685 on: March 26, 2020, 12:03:35 AM »
Thanks. I get proper voltages on both sides of R1 and R2.  R4 is the variable resistor, how do I properly check voltage to R4 without lifting pcb ? Where should I measure with multimeter?
« Reply #686 on: March 26, 2020, 04:17:09 AM »
OK so I built a 251 inspired mic from Matador and chunger I been seeking help and support but to little success, I even replied to the forum I know this isn't the correct forum but I'm hoping someone could help me out I had multiple issues bad styroflex caps but replaced those styroflex caps with silver mica and still no audio I rewired the t14 transformer and either way no audio I checked the ohms and they are correct I even wired them to direct output cap and ground points capsule is working fine I'm really not sure what the issue is could anyone help please? I'm getting 61v to the capsule c1 r17 r13 r12 polarity is good I'm also getting 124v and 6. 3v directly to the tube pin 5  someone please
Some pics here
https://ibb.co/9Yzkh2J
https://ibb.co/wg7N1YN
https://ibb.co/GVTY5GW
https://ibb.co/f8wdYKJ
https://ibb.co/JKJwwcj
https://ibb.co/cXt5J1T
Delta Sigma
« Reply #687 on: March 26, 2020, 10:54:36 AM »
Too many social distancing beers last night... I meant R6. If you have voltage at R2 but not the B+ side of R6 it could mean a bad R4 pot or a missed solder point on the R4 pot.
« Reply #688 on: March 26, 2020, 11:08:29 AM »
Hahaha...ohhh the good life lol. I’ll check tonight when I get home. I had a feeling as I was measuring voltages last week that R4 could have been the issue so I ordered a couple of more and I already replaced it but the issue remains. I’ll check again and let you know. Thank you so much.
« Reply #689 on: March 26, 2020, 02:27:15 PM »
Anyone.. Bump
« Reply #690 on: March 26, 2020, 08:11:26 PM »
Ok just checked and you are right. No voltage on either side of R6. Is it possible the second R4 trim pot to be faulty as well? That’s so strange. I have one more but since I have two failed in the same spot maybe I am missing something?
« Reply #691 on: March 26, 2020, 09:45:57 PM »
Could someone help me out
« Reply #692 on: March 28, 2020, 10:43:14 PM »
Ok swapped yet another trim pot for R4 and still no B+...any ideas why I am not getting any voltage beyond R4, at R6? Thanks.
TillM
« Reply #693 on: March 29, 2020, 05:31:53 AM »
Some pics here
Do you try another tube ?
Do you see your tube burn or not ?
The voltages look good.
Check continuety between your audio pins for xlr.
We need some infos ?
Where do you live, which capsule do you use and which tube (seams like GE 6072).
« Reply #694 on: March 29, 2020, 02:22:51 PM »
The capsule works fine I switched it to another mic it's a k67 from advanced audio, I have checked the XLR pins and everything seems to read correctly for pin 6 and 5 on audio this doesn't make sense, I have swapped 2 different tubes and they light up I only get some low audio after I crank my preamp to max 75db
TillM
that's what i mean, if the voltage are right, check the continuity from the audio pins from the microphone to the xlr out.
You have to check step  by step to prove which not work right.
You know, that your capsules is good, your tube burn, your voltage looks good.
So now we have to check other parts.
You said in another thread that zu had to repair your mic body.
Please check also the grounding continuity from every single part who must have grounding (look at the schematic).
Please clean your pcb ! (especially the area where your cables goes to the mic).
C3 need polarity, as far as I see you use a normal film capacitor (which is okay), but i would also check it out.
When you get low audio, when you crank up the pre, most of the time when I had this, it was a grounding issue.
So I would proper check the grounding again.
Check if your transformer primary has the right direction.
I don't know exactly how the cinemags are wired, but check if you don't reverse ground on the transformer.
« Last Edit: March 30, 2020, 07:55:35 PM by TillM »
