here is a print on the innerstage and OPT for the Altec 436C,
some info is missing as the OPT had a cooked primary,
21 EI lams are similar to 50 EI in case you want to build a 4651,
do not know what is going on with the center tap as i did not see one on the 4651 i took apart,
