SSL: switches or pots for attack/release
mikem
Member
can I easily replace the switches for attack / release to pots?
I think I have to connect a resistor with the first switch value in series with the first lead of the pot ?
should I connect pin3 of the pot to ground or let it open ?
thank you
mike
Hi Mike,
I think we've had this question before - try a search.
For the release, you can't use a pot, as the auto setting is a bit more complicated than this..
Jakob E.
i didn't find anything about that
nothing in the meta thread as well
I just looked at the pcb and i think to get the autorelease working,
I could use a switch that changes from step 1-5 (manual) to step 6 (auto)
what if I use a 250k pot instead of the switch, should I connect pin3 to gnd ??
thanks
mike
