Finally found the time to complete both channels with the mic pre options!
My unit is featuring prototypes of Bluzzi's 1290LE pcb.
And even though the 1290LE was designed to have a separated controls from the EZ1084 and actually would need extra space on a front panel, or even an entirely different box by itself, I wanted to stay as close to the original layout as possible.
If just building the 1290LE the way Jim designed it, with Grayhill and pushbutton switches, it should be VERY straight forward and EZ!
As mentioned before I had the 1290LE in mind when building my 2-1084 and I'm glad it worked the way I wanted!
Even though the enclosure is 38cm deep this box is fully packed now!!
I had to do a lot of handwiring again and also work close to the schematics e.g. for wiring the gain switch, since the original has 13 pos. for the Mic section plus 2 OFF positions as to where the EZ1290 LE has 12 positions for mic and no off positions.
Also the PAD and the Impedance switches are handwired in this unit to swichtes on the rear panel.
Like the 1084 pcbs, the 1290LE pcbs are stacked
Phantom Power is wired directly from the 48V rail of the power supply even though there's an option for it on the 1290LE pcb -
but I had prepared it this way already before receiving the 1290s
For anyone thinking about adding the 1290LE to your EZ1084 - do it!! This mic preamp sounds fantastic!!
And being able to shape the mic signal with the 1084 right there is golden!!
I was using it with an SM57 while checking if everything was working and I was amazed by how great a 57 can actually sound!
I can only imagine how amazing it will sound with my U47...
Kudos to Jim for the design work and thanks a 1000 times for making this possible!
