Looking fro the schematic or at least the block diagram for the Neve 1883 routing module as used in the 8104 console.
Chris said:A little rough...
API said:Hi Ian.
No, they are not interlocking and you can send to all four places if you like!
May i ask why you are curious about this?
dirty1_1garry said:More then that I found some info for 1943 route module. It's same as 1883 but contain 8 group outputs and 8 auxes.
My question regarding number of outputs to group buses. How much lines could be used from second BA283AM without signal loosing? At what factor this depends?
ruffrecords said:If you also route 8 buses at once without the pan pot, you have another 15K/8 = 1875 ohms.
dirty1_1garry said:ruffrecords said:If you also route 8 buses at once without the pan pot, you have another 15K/8 = 1875 ohms.
Regarding panorama potentiometers. What will be with pan pot? How this fact will change bus impedance?
1883 module use 10K lin double pot with 2K2 resistor in parallel.
If we use pan pot it will give 5K in middle position (signal in centre pan) for both buses (for example if it's just two)
So we will have 15K bus resistor plus 1527Ohm (5K+2K2 in parallel) = 16K527. Right?
Regarding value of pan pot. Neve modules use double 10K pots with 2K2. What purposes of 2K2?
In some schematics I saw 47K pot or just single pot. Which way and why better?)
