Mbira
Sorry for this newbie question, but I don't understand if I need to do anythign with pin 9 "G":
http://www.ti.com/lit/ds/symlink/tpic6b595.pdf
Here is what it says in the datasheet:
When output
enable (G) is held high, all data in the output
buffers is held low and all drain outputs are off.
When G is held low, data from the storage register
is transparent to the output buffers.
So does that mean I want G to be connected to ground if I'm using it in this sort of configuration:
http://arduino.cc/en/Tutorial/ShiftOut
I'm guessing G is the same as OE (Output Enable) on these other 595s?
When output
