Star Grounding a Tascam M3500
« on: April 16, 2014, 11:11:03 AM »
Hello all! I am in the middle of doing a full recap and mod of my Tascam M3500.. One of the mods I would like to do is the star grounding..I understand that we want to make a grounding bar branch to ground each channel to individually (i addition to it traveling thru PCB buss boards)...But my question is do I connect this ground bar leads to the 0 volt rails on the console? The Ground and 0v rails are connected on the schematics at the mic pre and line ins..otherwise its all 0v and the "ground is just between chassis and power supply chassis..
joakimkarlthomas
Re: Star Grounding a Tascam M3500
« Reply #1 on: March 11, 2018, 10:39:23 AM »
Hi! Did you make the the star ground mod? Where did you connect the star ground on the channels? I have a noisy m3500, would you recommend the star ground and the recap mod? Thanks!
