Bill Wilson
- Joined
- Apr 12, 2010
- Messages
- 253
This unit was designed by a close friend of mine & used it in his recording & sound business (late 40's-mid 50's). He gave me the schematic & a Kenyon output transformer. He used the diagram for the Western Electric 22D remote broadcast amplifier. I have included the page on the 22D from my Audio Facilities by Western Electric catalog; probabley dating from the late 40's or very early 50's.
The input transformer can be any unit that has 50, 150, 250 ohm input impedance; with a secondary from 40- 80k ohms impedance. The output transformer must have a primary of approx. 10k ohm impedance, that has a center tap with secondary winding w 600 ohm, & 250 ohms impedance with the ability to handle +20dbm.
The schematic shows 3ea. 30 ohm impedance daven rotary controls having 2db per step, but falling logrithmacly at near the off or closed position. This was due to his using Western Electric Mikes, that had an output impedance or 30-50 ohms. A more up to date implementation would use 250 ohm daven type stepped attenuators. The output switching can be ignored as you would not need facilities for a second telephone order line to communicate with master control at the radio station. You are free to use this circuit as you see fit as I am now the copyright owner.
