Bill Wilson
- Joined
- Apr 12, 2010
- Messages
- 253
This is the mike preamp of the tube mixer I designed in 64, for my on location master taping business. The mixer had 6 mike preamps
that fed a L,R, center switch on each channel. The output of the switches fed the high impedance mix buses; these were fed to the stereo output amps & fed to the top of the 100k record level pot on my Ampex 351-2 recorder.
The frequency response was limited by the UTC transformers. Freq. response= -1db @30cps., flat from 50 to 18kcps., - .5db 20kcps. for those who do not recognize the cps. term, it is cycles per second & predates the hertz designation; (personally I prefer it).
This is a class A circuit as no feedback is used. It is very clean w distortion so low it cannot be heard. In case you are wondering why there is no bypass capacitor across the cathode resistor; that was a trick employed in the early days of vacuum tube design in order to get more gain from a circuit. By not using a bypass cap the gain is less & results in a very quiet mike pre. Eve Anna Manley agreed with this on diy audio, 4-5 yrs. ago.
More to follow. P. S. In order to see the entire image right click your mouse & select VIEW IMAGE; this will show the entire drawing.
Sorry I do not know how to make the image smaller.
