Retired:Symmetrical FET
« on: May 16, 2014, 04:07:03 AM »
PCB for an 1178/stereo 1176 circuit, designed with the help of the great people on this forum.
Left for archiving.
Schematic -  (errata - 30K should be 30R1)
BOM In addition to the list, I have been using NOS NPD5566 dual JFETs.
Board Layout
Hope you enjoy!
Gustav
« Last Edit: August 07, 2015, 09:12:15 AM by Gustav »
Greg S.
Re: Symmetrical FET
« Reply #1 on: June 30, 2014, 05:12:49 PM »
Does someone have a Backside Pic showing the connection of the Com ports between the main pcb and the gr/meter board?
thx
Greg S.
Re: Symmetrical FET
« Reply #2 on: July 01, 2014, 09:58:43 AM »
I belive, i got it..
I prefer 3 IDC 8-pin connectors
Layout Com2!
https://pcbgrinder.com/download/Symmetrical-Fet/Symmetrical-Fet-board.pdf
There is a single pin at the Main-Board's right side upper line which should be wired to the GR-Board's right side down line
This is the key!
Re: Symmetrical FET
« Reply #3 on: July 01, 2014, 02:41:20 PM »
Greg, if you check the board drawing, they are "lined up", but I had this connecting in mind, which should make it obvious.
- Will be adding some more documentation to this project, when I get the correct size pots :)
Gustav
Greg S.
Re: Symmetrical FET
« Reply #4 on: July 01, 2014, 03:10:29 PM »
Hi G!
Check both rightsided Pins!
Re: Symmetrical FET
« Reply #5 on: July 01, 2014, 03:18:16 PM »
Hi G!
Sure, but it could be a trap!
Its still easier to just "think like the connector" I posted. Not much wizardry to it, really.  :)
Gustav
Greg S.
Re: Symmetrical FET
« Reply #6 on: July 01, 2014, 03:39:50 PM »
Always Funny... Sunny   ;D ;D
Greg S.
Re: Symmetrical FET
« Reply #7 on: July 02, 2014, 02:02:49 AM »
I got the last missing parts today, so I can complete the 1178.. We will see G.
Suggestions for the next Revision:
   2 Meter light circuits at the PSU
   Com1-3 Pin inscription
Would be great G!
In the End it's DIY and I simply love building those boxes
Re: Symmetrical FET
« Reply #8 on: July 02, 2014, 07:58:47 AM »
Its hard to foresee what people do to ones design - This was designed for the angled connector to avoid wiring completely :)
Gustav
Greg S.
Re: Symmetrical FET
« Reply #9 on: July 02, 2014, 10:28:24 AM »
Almost there,,
Some features are still not done.. (holes at the front) ..
But as far as the Com-Port-Problem/Discussion isn't solved, I wont start it up!
But it's already quite good looking..
Re: Symmetrical FET
« Reply #10 on: July 02, 2014, 12:20:51 PM »
Sorry, I thought you already worked it out from the picture I posted.
Heres a different angle showing how the connector hooks up from the main board to the control board. Since you're not using the intended connector, just lay out how your chosen connectors/wires would follow the same path...
Gustav
Greg S.
Re: Symmetrical FET
« Reply #11 on: July 03, 2014, 03:56:59 AM »
It's working.
my Com's were right!  8)
My NPD5566 seem to work too..
(Have to calibrate. 'em)
I will match some BF245a's just for fun and try 'em too..
Which Fet's did you tried?
No Hum, thats fine.
Is there a reason, why you changed the Input Pot to 1K (original get's 10K)
I got a 22k lin at the Attack, 25k are hard to find
Changing the ratios didn't have so much effect..
I got a bit white noise at the outs,.
The noise is always there, it's not effected by some pots!
HMMM, thinking about that!
Will rewire by using shielded Cables
Next up:
The both Elcos at the outs are free to choose from 2200uF-4700uF
The G-1176 got 470uF, might you comment on that G?
Re: Symmetrical FET
« Reply #12 on: July 03, 2014, 06:36:16 AM »
It's working.
The pictures you sent me by mail were fakes, but I will be checking some of those too
Only original NPD5566 so far. I have a stack of different types, I Will be doing experiments with before offering a kit.
No Hum, thats fine.
The original is 1K, so I can't comment on a reason to change it from 10K.
22K/25K - Different series land on different values (Alpha pots land on 25K, OMEG on 22K), but I consider those identical.
Maybe the transistor you used isn't a good choice, or maybe your lack of calibration plays a part. Worked perfectly here.
Since you're using alternative wiring, you may experience alternative results from my prototypes. Measurements were fine here.
Next up:
Its what I had laying around/tested it with, so the note stayed on the silk screen. You could probably ask the same for a few other values in the build. You may not even need it, and if you run transformerless, bigger can't hurt in case your signal should see some ginormeous impedance..
Gustav
« Last Edit: July 03, 2014, 08:12:07 AM by Gustav »
gyraf
Re: Symmetrical FET
« Reply #13 on: July 03, 2014, 09:58:22 AM »
Remember that this circuit lowers the threshold when you select lower ratio - trying to keep average GR the same. This means that you can't expect levels to change significantly with ratio - measure real ratio by comparing input level increase (initially over-threshold) of say 10dB to output increase dB.
Jakob E.
Greg S.
Re: Symmetrical FET
« Reply #14 on: July 19, 2014, 05:01:41 AM »
Jakob E.
Dear Jakob,,
I finally found yesterday a really good pair of BF245a's, Mason's Site was very helpfull.. thx Mason..
The effect of compression is not as good a pair of Gustav's 1176ers.(Rev V/K, sold out meanwhile)
Do you have any suggestions for other Fet's?
BF245B? 2N5457?
Or what did you used?
Re: Symmetrical FET
« Reply #15 on: July 19, 2014, 12:27:15 PM »
Jakob E.
Dear Jakob,,
BF245B? 2N5457?
Jakob didn't build this unit, so he would have no way of answering this.
As mentioned, I only built it with the original NPD5566 thus far, but I will be trying out some different FETs, after I get an order of pots in.
Did the fake you tried out not work?
Gustav
(And a side note, Phat Phet=my final 1176 board revision, so not sold out but updated)
Greg S.
Re: Symmetrical FET
« Reply #16 on: July 20, 2014, 08:02:13 AM »
I meant your early 1176er that are close to Mnats layout G.
I don't have any others 76ers PCB's..
This is what I got for my three NPD5566 B0923 from eBay - 5bugs each..
They seem to work, Both Channels are pretty close-up, but the all div to each other..
Greg S.
Re: Symmetrical FET
« Reply #17 on: July 20, 2014, 08:04:17 AM »
as jpg
Greg S.
Re: Symmetrical FET
« Reply #18 on: July 20, 2014, 11:01:18 AM »
working now!!!  NPD5566 is doing what it should.
by the way, 3 different Ratios, right?
I will hard-wire anything,
hope, my tiny white noise is affected by the molex I used..
but in the end, it's all right..
THX for all that were part of this Project.
It's been a great Pleasure and a Privileg for me!
Special THX to Gustav..
« Last Edit: July 20, 2014, 11:35:04 AM by Greg S. »
Greg S.
Re: Symmetrical FET
« Reply #19 on: August 13, 2014, 06:50:46 PM »
I reworked the Frontpanel and the Wirings, no more Molex and I added a MU-Shield for the Transformer!
Noise got less..  :)
But there is still some at one channel, but I will get this!
