Could any of you fine gentlepeople tell me if this looks OK.
Would it be better to use a transformer with dual secondaries and use two bridge rectifiers going into what are essentially two separate supplies and ditch the doubler, or is what I have now OK? Did I do the math right for the LM317? (side note: the HV is spec'ed to output up to 57V max, so I figured 48V wouldn't be a problem)
[Edit]
Thanks a bundle!
[Edit]
Thanks a bundle!
