robomatique
G9 Capacitors
« on: June 19, 2004, 08:13:53 AM »
Hello,
I am just about to write a part list for the G9 in the UK and I am having some trouble with finding the polyester capacitors with the correct pitch. I have also understood that the quality of many of these capacitors make a big differents.
So:
1. Does anybody have a parts list for the UK / Europe?
2. Could anyone recommend a supplyer in the UK (I normally use Rapid)?
3. Could anyone recommend good quality brand or type of capacitor for these type of applications (really good if they were distributed in europe)?
4. Could I use Metallised polyester, or maybe even metallised polypropylene?
I am totally lost when it comes to these things, so if not for me, please help the G9, I think he is worth the right capacitors.
Robert
"Trying is the first step towards failure."
-H. Simpson
mcs
Re: G9 Capacitors
« Reply #1 on: June 19, 2004, 08:24:25 AM »
Quote from: "robomatique"
No, I just look through my drawers where I can probably find 99% of the needed caps :grin:
Farnell has a huge selection of caps in their catalogue - you can find caps with almost any needed pitch. RS is another good source. Neither of them are cheap, but you can get all the parts from them (and in small quantities).
I would use polypropylene or metallised polypropylenes (MKP/FKP). You can get good types from Philips (BC), Rifa, Wima, Epcos and more.
Best regards,
Mikkel C. Simonsen
rafafredd
G9 Capacitors
« Reply #2 on: June 19, 2004, 10:17:00 AM »
Well, Jakob always recommends Polyesters for the G9. Yes, you can try polypropylene...
robomatique
G9 Capacitors
« Reply #3 on: June 19, 2004, 10:31:49 AM »
Thanks guys, I will see what I can find.
Another one: Should I use as high quality as I can afford on the potentiometer, or could I use a cheaper one? Would it be worth the mone spending 10 bucks on one?
Robert
-H. Simpson
mcs
G9 Capacitors
« Reply #4 on: June 19, 2004, 08:18:03 PM »
Quote from: "rafafredd"
But it looks like he uses some polypropylenes himself... If you look at the photos on gyraf.dk it looks like half polyester and half polypropylene.
Best regards,
Mikkel C. Simonsen
mcs
G9 Capacitors
« Reply #5 on: June 19, 2004, 08:23:20 PM »
The difference between good pots and expensive ones is usually channel to channel matching. A pot costing £1-2 should be fine.
Best regards,
Mikkel C. Simonsen
mcs
Re: G9 Capacitors
« Reply #6 on: June 21, 2004, 01:34:39 PM »
Quote from: "mcs"
I decided to try - assembling a G9 board fealt like a nice thing to do on a sunday afternoon...
This is how far I got using just parts from my "junk box":
I guess my junx box is well assorted :green:
Best regards,
Mikkel C. Simonsen
Smoke
G9 Capacitors
« Reply #7 on: November 22, 2004, 01:03:55 AM »
what are those strange looking jumers just above C24?
soundguy
G9 Capacitors
« Reply #8 on: November 22, 2004, 01:19:52 AM »
zero ohm resistors.
dave
chips are good with dip...
tubejay
G9 Capacitors
« Reply #9 on: November 22, 2004, 09:06:08 AM »
Quote from: "soundguy"
zero ohm resistors.
dave
I'm officially uncool, because I got that!  That's the type of joke you tell your wife, and she leaves you and slaps a pocket protector on you on the way out the door.
That makes me give a big geeky thumbs up!   :thumb:
zebra50
G9 Capacitors
« Reply #10 on: November 22, 2004, 09:28:55 AM »
Ribbon microphone services
http://www.xaudia.com
Microphone blog
tamtamstudio
G9 Capacitors
« Reply #11 on: December 14, 2004, 10:20:49 AM »
Hi Jakob, i buyed for an error a couple of this caps, can I use in G9?
http://homepage.mac.com/tamtamstudio/PhotoAlbum13.html
It can be enough the caps voltage?
gyraf
G9 Capacitors
« Reply #12 on: December 14, 2004, 10:22:42 AM »
No, 250V is not enough for the PSU reservoir caps, if that's what you're thinking of. They need to be 350V or more.
Jakob E.
tamtamstudio
G9 Capacitors
« Reply #13 on: December 14, 2004, 10:26:25 AM »
:cry:
I hoped that i could use it, but the voltage seems too low..
I need to exchange with others..
THX
Svart
G9 Capacitors
« Reply #14 on: December 14, 2004, 10:27:44 AM »
polypro or polyester, they are both excellent caps.  I hear that metallized ones aren't as good for audio coupling but i haven't been able to HEAR a difference myself.  polypro will give a slightly clearer sound, polyester will give a more smooth sound when used as audio coupling caps, however the sound is so slight that you would need a whole channel of nothing but either to start to hear the difference..  so use whichever you can get and you will be happy with either!
Welcome to the GroupDIY leper colony! when something falls off, we just replace it with a tube!
occupation: General Electron Mayhem
Alesis X2 information repository:
http://www.theopiumdenproductions.
gyraf
G9 Capacitors
« Reply #15 on: December 14, 2004, 10:41:34 AM »
Tamtamtam,
You could use them for a G7-type microphone PSU?
Jakob E.
tamtamstudio
G9 Capacitors
« Reply #16 on: December 14, 2004, 12:12:58 PM »
Yes, was buyed for this reason, but I buyed  2 times more..
now I've got 6 G7, it's enough.. :grin:
tony dB
G9 Capacitors
« Reply #17 on: December 17, 2004, 12:05:24 PM »
i can only get some Polyesters via Farnell and they only seem to stock PANASONIC'S, are these any good? I've seen messages concerning different brands, so i wonder?
(it's the interstage, output DC coupling, gain DC coupling, SRPP ouput, stabilisors and HT stuff)
Tony
mikeyB
G9 capacitors
« Reply #18 on: October 11, 2005, 09:22:23 AM »
Can crossover caps be used  - seen these at cpc.co.uk - part numbers:
CA02439/CA02499/CA02502 or CA02528/CA02537.
These are polypropylene or plastic film caps with a rating of 250VDC, 5% tolerance and the correct pitch spacings.
Can a Lundhall 1517 be used on the output (just salvaged a couple!) - i'll have to make adaptor with verocard.
Finally - can a 317 be used in place of 783 - so some thread from Jakob but i can't find it now! I've just repaired a 2nd purepath and in both cases it looks like the TL783 has crapped out and took the switchmode input with it. I've used them elsewhere and never been sure how reliable they are?
making better music!
gyraf
Re: G9 capacitors
« Reply #19 on: October 11, 2005, 12:40:47 PM »
Hi Mikey!
Quote from: "mikeyB"
Yes, speaker crossover polyester or polypropylene capacitors are good for our purpose.
I don't think so - but check the specs at Lundahl. I suspect it has too low an inductance to allow proper low-end. But try..
No. You NEED a TL783 here - we need it's tolerance to rather high input/output voltage differences. The '783 only craps out if it's not properly protected in the circuit (and we protect it alright - it'll only die if you short the HT supply, which is a bad idea anyways.)
Jakob E.
Last post December 15, 2004, 01:44:20 PM
by soundguy
Last post January 03, 2005, 09:55:50 PM
by CJ
Last post February 09, 2005, 12:29:01 AM
by PRR
Last post April 05, 2005, 01:54:27 PM
by [email protected]
