Seditionary
Rare parametric EQ pair designed by Bob Orban. Sought after units with great reviews. Original power supplies. These sound beautiful.
I will also include a pair of Mogami cables to correct for phase and balance -- These equalizer are built 3 pin hot (meaning without an adapter cable, using the eq would bring your signal out of phase as most likely, your other gear is 2 pin hot). I built adapter cables to balance the EQs via the schematic on the Jensen white pages to convert the output of the units to 2 pin hot to keep your signals in phase, balanced correctly, and your signals sounding beautiful
Also, I know a simple modification on these equalizers recommended by Bob Orban. I can deliver the eqs modded via Bob Orban's specs or can deliver an original factory unit. Your choice
