bernbrue
Re: [BUILD] The Rude Tube IVORY ====== Official build & support thread
« Reply #20 on: June 09, 2014, 02:50:02 PM »
Hi Winetree,
yes, the IVORY sounds really cool. Yeah, I know, too much unfinished projects, BUT this one is going to amuse you. Provided all parts are there, it´s a really nice build for a Saturday afternoon.
regards
Bernd
bernbrue
« Reply #21 on: June 10, 2014, 07:19:57 AM »
update:
added frontpanels & drilling templates for download
regards
Bernd
tsv
« Reply #22 on: June 10, 2014, 11:37:40 AM »
Great thanks!
dribro
« Reply #23 on: June 14, 2014, 05:54:30 PM »
Sounds really good! thanks for sharing this!
 Can you estimate how much will it be for a stereo version? Haven't check all parts, sorry. Also, I seem to get truncated data when downloading the musikding chart... Can you provide maybe a pdf?
zayance
« Reply #24 on: June 15, 2014, 04:16:10 AM »
Hi dribro,
Forward your email on PM, and i'll send the musikding shopping card.
Best Regards,
T.
SKJGProject
« Reply #25 on: June 18, 2014, 05:48:51 AM »
received my pcb, what a piece of art!
I used to date a blind girl. Her name was ::… ..:.: .:::. .::.. ….: .:.::
bernbrue
« Reply #26 on: June 18, 2014, 07:32:43 AM »
Good to hear that you like it. Happy soldering!
regards
Bernd
bernbrue
« Reply #27 on: June 20, 2014, 09:00:33 AM »
updated first post. Built almost done!
regards
Bernd
« Reply #28 on: June 24, 2014, 02:50:18 PM »
this looks really cool.
so this is the eq and drive section of a fender without the actual amp?
if so - what kind of input- and output impedance does the unit have? or is it an actual guitar amp? little confused- but very interested :)
bernbrue
« Reply #29 on: June 24, 2014, 02:59:59 PM »
today I powered up the psu . It´s performs flawlessly. :) :)
@ Salomonander: It´s in fact the slightly modified preamp stage & EQ of the Fender Blackface Champ. You can add a 6V6 tube and transformer and you´ve got a nice little guitar amp.
regards
Bernd
culteousness1
« Reply #30 on: June 24, 2014, 04:32:50 PM »
Hi Bernd!
I couldn't find a transformer in the BOM or in the Musikding cart you posted.
Which PT did you use? I am worried because of the little height in 1 RU...
Carsten
"What's all this analog stuff anyhow?" - Bob Pease
"My favorite programming language is ... solder." - Bob Pease
zayance
« Reply #31 on: June 24, 2014, 04:43:08 PM »
Hi Bernd!
Carsten
Hi Carsten,
On the preliminary Build docs, you have refs of PT to be used in a 1U without problems.
Bernd had precised that Musikding Shopping card didn't include T0220 Insulators nor Power transformer unfortunatly.
I personnaly bought the tt-t47 from Tube Town, it's height is good for 1U, but there are others, check the docs @ Mains + Extra
Hope this helps.
T.
« Last Edit: June 24, 2014, 04:49:03 PM by zayance »
bernbrue
« Reply #32 on: June 27, 2014, 12:37:01 PM »
Update: the IVORY works perfectly!
cheers
Bernd
Winetree
« Reply #33 on: June 27, 2014, 02:20:51 PM »
Is there going to be another run of P.S.B.
bernbrue
« Reply #34 on: June 27, 2014, 02:24:19 PM »
Yes, there will be another batch of pcbs.
Zayance is making a list of interested people.
Have a look at his WM thread.
http://groupdiy.com/index.php?topic=53011.0
Write him a pm.
« Last Edit: June 27, 2014, 02:31:57 PM by bernbrue »
zayance
« Reply #35 on: June 30, 2014, 05:52:25 AM »
Hi Folks,
I'll be finishing mine this week i guess, was busy on some other stuff.
i'll be building mine in a 1U rack, and so for you to see how this one fits and behaves well in a 1U version.
Of course in 1U, care should be taken on choosing capacitors and heatsinks and power transformer that will fit, and the preliminary docs
gives the infos needed.
Pictures will be taken along the build, and i'll add them to the Build doc.
If anyone is interested, please feel free to send me a PM so i can add them to the feeler list that you can see on my WM page.
Thanks a lot
T.
tsv
« Reply #36 on: June 30, 2014, 08:48:04 PM »
My boards arrived today! They look amazing. Nice work!
I'll order the rest of the parts now. I only have the Antek transformer :)
tsv
« Reply #37 on: July 01, 2014, 12:11:27 PM »
What would be a proper fuse size for the 50VA transformer for this project? I am using
http://www.antekinc.com/as-05t200-50va-200v-transformer/   US 115VAC
bernbrue
« Reply #38 on: July 01, 2014, 02:02:33 PM »
be aware that you need 9VAC in order to get rectified and regulated 6,3VDC heater supply. If you really want to use this transformer, you should take the 6,3VAC directly from the transformer to the tube without stuffing the heater rail on the psu board.
So, either 6,3V alternate current directly to tube or 9V alternate current to psu to get 6,3V direct current.
If you want to go that route I would take the model with higher B+ like this one:
http://www.antekinc.com/as-05t240-50va-240v-transformer/
regards
Bernd
tsv
« Reply #39 on: July 01, 2014, 02:48:19 PM »
Hi Bernd
Thanks for your response. Unfortunately that transformer is out of stock and I already purchased the 200V version. It's one of the 3 suggested transformers in the build docs for US. I wasn't aware that I needed a 9V AC tap on the transformer but looking at the schematic I see what you are saying. All the transformers listed in the build doc including the European ones are only 6.3VAC. The build docs should be updated to highlight this.
So do you think the 50VA 200V transformer I purchased is enough to run 2 channels?
