joaquins said:
How would a second harmonic introduce DC if it's a sine function with no DC? You would be summing two signals with no DC and no DC as result. It shift half cycle up and half down, any harmonic distortion will introduce DC...
Mains transformers usually operate ju..ust under saturation. Saturation results in higher current on the peaks. You can see this by looking at the Magnetising current.
If there are even harmonics on the mains, one cycle will have a higher peak than the other. A higher peak on one cycle means the Magnetising current has a bigger peak on one side .. ie a
DC current is introduced .. even if the Voltage has no DC component.
