Universal Audio UA 176 - Limiting Amplifier
JBB
Active member
Russia, Moscow
Implemented another project:
Photos of the project: http://jbb.ru/176/
Layout UA 176: http://jbb.ru/schematics/176-layout.htm
Scheme UA 176: http://jbb.ru/schematics/176-shem.htm
Layout UA 175b: http://jbb.ru/schematics/175b-layout.htm
Scheme UA 175b: http://jbb.ru/schematics/175b-shem.htm
BOM UA 175b/176 http://jbb.ru/schematics/UA_175_176_BOM.xlsx
ilfungo said:
Great  Build JBB!!!
How is the sound?
Thank you.
The sound is very close to the original 176
Here you can listen to audio samples of the two Compressor - 176 and 175B to the master mix.
https://translate.google.ru/translate?sl=ru&tl=en&js=y&prev=_t&hl=ru&ie=UTF-8&u=http%3A%2F%2Fforum.guitarplayer.ru%2Findex.php%3Ftopic%3D318503.msg7887650%23msg7887650&edit-text=&act=url
1.mp3 - without compressors
2.mp3 - processing compressors
ilfungo said:
Thanks JBB
can you send me a link without translation?
I can't listen the mp3...
1.mp3 - without compressors:
http://forum.guitarplayer.ru/index.php?action=dlattach;topic=318503.0;attach=1065233
2.mp3 - processing compressors:
http://forum.guitarplayer.ru/index.php?action=dlattach;topic=318503.0;attach=1065234
THANKS JBB!!!
2 info:
on layout : Un - Ch- Ua  where are connected?
I've one UTC A10 can work as input?
There is an alternative to Sowter as interstage?
THANKS!!!
Un  - filament voltage (5v)
Ua  - anode voltage (325v)
Ch  - shoke
UTC A10 this is what need.
There are many alternatives to the interstage transformers.
Hammond, Cinemag, Lundahl - it is also possible to use.
Specify the exact analogues transformers cannot.  Have not studied the issue in this direction.
Hi
Transformer UTC O-1 can also be used.
Here to discuss the same issue: http://groupdiy.com/index.php?topic=17654.0
Nightmare, ( semi-joking )
now I'm gonna have to build this too. ( serious )
Thanks JBB, you are a very kind man to share this info so elegantly  ( actually )
regards
Michael
Hi
I'm building the 176!!!
I want to implement like Retro 176 the asymmetrical function and interstage trafo bypass,
Can someone help me?
THANKS!!!
Hi JBB
I'm starting and I'm waiting the output transformer from sowter...
When the project is on the way I will post some images.
Asymmetry switches?
Interstage Bypass?
HP Filter?
THANKS!!!
