Issue with attack pot on FET Compressor Revision A Complete Kit
Maxby
New member
The attack button on my FET Compressor Revision A Complete Kit of Hairball Audio doesn't work except the OFF position...
All the wires seems to be Ok...
What can create this problem ?
All the rest of the compressor is functioning.
Thank you for your help !
Sorry for my french ;D
Max
i dont know this circuit. but if you are certain that the pot is correctly wired, id try to measure the components that surround it in the schematic. you might just have a bad or wrong value part somewhere in the circuit. hold the pcb against very bright light in order to check for shorts.
