Looks like a good clean build!
Maybe a defective part.
Have you double checked all our cabling/patchbay to make sure something isn't out of polarity or unbalanced?
You could always send it in if you like, we're happy to look over weird acting builds.
Mike
Thanks Mike... gain issues with the mic input have been sorted out as far as I'm concerned... I'm just not used to cranking volume controls so much. I might look into upgrading the pots to Grayhills, eventually.
The DI situation however, isn't solved. Tried different instruments and cables without success. Although "some" signal passes through, it is still highly distorted. It's even more obvious with a signal from a higher-gain source such as music playing back from my iPhone. Just nasty distorted.
I'll hold on to shipping it back until I get the other one finished and tested... plus, I really enjoy troubleshooting stuff
We'll move on from there.
P
