resilient
Re: [BUILD] Hairball Audio - Elements
« Reply #400 on: March 26, 2019, 05:28:23 PM »
Thanks, Mike.  I'll double check them.
I've got an extender coming tomorrow, so I'll be able to grab some measurements at that point, too.
Brandon
resilient
« Reply #401 on: March 26, 2019, 06:28:25 PM »
Ok, editing this thing for updates.
I have signal!  But it's low except in the highest position.  And it seems to be correct in that position... wide open and distorted (the distortion actually sounds kind of nice!).
I have reflowed all input control solder joints, including those on the Grayhill board.  Any thoughts on what might cause this low output until I get to the last setting?
Brandon
« Last Edit: March 26, 2019, 11:24:12 PM by resilient »
Hairball Audio
« Reply #402 on: March 27, 2019, 01:30:40 PM »
Brandon
Check your gain switch resistor placement and soldering. At full gain you bypass those resistors. As you turn it down you start adding them from lowest value to highest value like a ladder.
Mike
Hairball Audio, LLC
DIY Parts and Kits
https://hairballaudio.com
Top secret stuff and upcoming releases:
http://instagram.com/Hairballaudio
http://facebook.com/hairballaudio
resilient
« Reply #403 on: March 30, 2019, 01:38:58 PM »
Found it!  I had mixed up R3 and R10.  Changed those around and all is well.  Thanks, Mike!
Brandon
Hairball Audio
« Reply #404 on: April 01, 2019, 10:00:01 PM »
Brandon
Nice!
Hairball Audio, LLC
DIY Parts and Kits
JOHN5
« Reply #405 on: April 28, 2019, 10:23:09 AM »
Hi Mike -
I have two Copper units that I'm having some trouble with.  Here's where I'm at:
Unit #1 -
-No sound except for a significant humming - - I'd describe it as a ground-related noise due to its regularity and constant presence regardless of whether an input is present (mic or DI).
-I checked resistivity w/ no op amp against my working unit (#2 - - see below)  All readings check out the same.  I have a spreadsheet of the readings I can send to you
-I swapped op amps with my working unit.  Both my op amps work in unit #2
Unit #2 -
-Works and sounds great except for the same humming as unit #1
-I've controlled for my 500 series rack slot:  I swapped another piece of 500 series gear (capi VP312DI) into the slots I had used for the hairball units.  No humming from the Capi unit when using same cabling and microphones for testing as the hairball unit.
I've double-checked component placement on each and am not sure where to go next.  Any thoughts?
John
Hairball Audio
« Reply #406 on: April 28, 2019, 02:52:21 PM »
Hi Mike -
Unit #1 -
Unit #2 -
John
Many repairs with coppers often boil down to the soldering around the larger vertically placed blue caps specifically cold joints on the ground pad.  There is a lot of heat sinking happening so you have to be patient with the heating of the pads.
Not sure about the hum.  Maybe the same stuffing error was made twice?
Usual note:
We do $50 flat rate repair on those if that interest you.
***I will be traveling Wednesday April 24th through Monday April 29th and will be slower responding during that time***
Hairball Audio, LLC
DIY Parts and Kits
dp
« Reply #407 on: June 11, 2019, 01:48:03 PM »
Ordered-up a Copper and it should be here by Thursday. Really looking forward to this build. I've been really happy with the "Neve sound" I've been getting from the Softube Console 1 British Class A plugin but I think this thing will take that to a whole new level!
dp
« Reply #408 on: June 12, 2019, 07:42:35 PM »
Got the kit today... a day early... now that's serendipity!
Just started the build.
dp
« Reply #409 on: June 12, 2019, 09:39:36 PM »
Missing the 2N4401... it's just part of the relay circuit so I should be able to swap in a 2N3904 without any issues, correct?
dp
« Reply #410 on: June 17, 2019, 09:50:50 PM »
Copper build update:
I got all the missing parts issues sorted out. I was missing the relay and its transistor and the 12k7 resistor in one of the Grayhill pots. Hairball got the transistor and relay shipped out quickly... thanks for that. The resistor I didn't discover until I was putting the Grayhill assembly together. I was easily able to put a couple resistors from my 1/2-watt MF set I use for my tube amps in series to get exactly 12k7. A little large but because of where it is on the board I was able to fit it in with no trouble.
Finished the build tonight and it works great straight-away... man that's a good feeling, isn't it?
This thing sounds fantastic. I re-tracked some vocals and was A/B'ing against some stuff I recently did with my modded-NT2 and the DIYRE CP5 with the Royal Blue colour module. They both sound really good, The CP5/Blue have a lot of high-end sparkle and some heft to it. Very clear and present. The Copper has the low-end and mid-range power you would expect from a "Neve" sound. Driven hard of course it will distort in a pleasing way. Set "on the edge" it sounds really good to my ears - the sweet spot. This thing is going to get used a lot. Have not tried the DI yet.
