wstratton
Re: D-EF47 Tribute To Oliver Archut U47 Build Thread.
« Reply #380 on: June 16, 2020, 08:34:49 PM »
Make a wire jumper on the PSU pcb between "COM" and "CRD" then you are in fixed cardioid mode, leave out the lorlin switch.
Thank you, TLRT, that makes sense. I haven’t been able to find a straight answer online about the differences in frequency response between a KK47 and the one-sided TLM-49, aside from reading that the TLM-49 capsule has a narrower sweet spot, tending more toward hypercardioid. I think I’ll probably go in another direction, but it’s on eBay for 300 if someone braver (or more foolhardy?) than I decides to buy it and see how it stacks up.
TLRT
« Reply #381 on: June 17, 2020, 05:27:46 PM »
For what style would you use the mic? I would rather use a good M7 capsule for EF800/802 tube.
wstratton
« Reply #382 on: June 22, 2020, 02:52:16 PM »
Mostly close-mic'd tenor male vocals. I'll probably do some room mic'ing too. I used to have a Soundelux E-47C, which used a Thiersch K-47 style capsule, and I found that to be a little too aggressive in the midrange. I decided to go with a Thiersch Blue Line m7 style capsule for this build.
« Reply #383 on: August 31, 2020, 06:36:31 PM »
Hi all,
First time posting here.  Just finished assembling the PSU and microphone.  PSU voltages test fine with dummy loads.  When I connect the microphone, the B+ voltage drops way down.  With the trim pot set to maximum, I can only get the B+ to come up to 80 VDC.  I replaced the front capsule with a 67 pF capacitor with no change.  B+ is still low.  Any advice as to where I should look next is much appreciated.
Thanks in advance!
Delta Sigma
« Reply #384 on: September 02, 2020, 01:46:26 PM »
Hi all,
Thanks in advance!
Is your heater adjusted properly? Don't adjust your B+ unless your heater voltage is where you want it. You could have a short or an incorrect component value somewhere. Don't just check your mic amp, it could be in your cable (short in the connector).
« Reply #385 on: September 02, 2020, 03:36:44 PM »
Thanks so much for your response, Delta Sigma.  Yup.  I had the B+ and the Pattern wires crossed on the mic connector :-\  I feel pretty stupid not catching that myself.  In my own defense, it was late at night.
Thanks again.  Now to plug it in and see how it sounds!
« Reply #386 on: October 20, 2020, 11:49:32 PM »
Hey guys, I am thinking of starting a EF47. I am not very good at reading schematics so I wanted to ask. Apart from tube and relay/pattern selection how close is this circuit to the original? I see that the grid resistor (r2 I believe) is 1G. Is there a specific reason for this instead of using 60 or 100M as in the original? Could I use 100M if I wanted to stay closer to the original? Or maybe 1G compensates for less bass using ef800 compared to vf14???? Thanks
« Last Edit: October 21, 2020, 12:41:35 AM by Purplenoise »
wstratton
« Reply #387 on: October 26, 2020, 02:42:36 PM »
I finally finished my slightly modified D-EF47 build today! Plugged it in for the first time, and it sounds absolutely fantastic. No harsh sibilance to speak of, even when singing right on the grille. Currently using an NOS Amperex EF-80 tube, but I think I'll stock up on a couple NOS Telefunken EF-800's over the next year or so. Even with the EF-80, this mic has extremely low self-noise. Thank you very much to Dan/Dany and Oliver (RIP) for making these builds possible, to Spencer for the beautifully machined body, and to Dennis at AMI for advice on the cable wiring and a circuit modification to accomodate a pre-built PSU.
Because I was wary of working closely with high voltages, I ended up ordering an AMI power supply after getting most of the way through building my own PSU, and Dennis very kindly gave me some advice on swapping out a couple resistors in Dany's PCB in order to accomodate this change. I ended up using a Thiersch Blueline capsule and AMI's T47 transformer. So far, I think the sound compares very favorably to the previous tube microphones I have owned. I used to have a Soundelux E-47C, which was a beautiful mic, but I found that the Thiersch K47 capsule gave it a pretty harsh midrange on my voice. Before that I owned a Pearlman TM-2, and I had the same problem with that microphone (again, on my voice--it was a beautiful microphone on many other sources).
Aside from being intimidated by the wiring on the PSU, which I ultimately gave up on, I found that the only really pesky part of this build was wiring the microphone's 7 pin cable, in particular getting the grounding right the Amphenol connector--the Binder connector that I ordered to connect to the PSU was much easier due to its more robust construction. My only advice on this is to take it slow if you're using unmatched 7 pin connectors and to think through various methods for grounding.
I tried to upload a picture of the microphone, but the board's server is rejecting it despite it being within the size guidelines, so here's a link to a Dropbox file if you want to see it: https://www.dropbox.com/s/b84tl2kh185be8p/IMG-0153.jpg?dl=0 I used an enamel snake pin for the mic's badge, in tribute to it being a sibilance tamer (the hissing of the snake--dorky, I know).
FYI, if anyone is having trouble with wiring their PSU build, I have a small collection of photographs of finished PSU builds for reference that other builders have kindly sent me--if you PM me I can dig them up and send them to you.
I'm extremely happy with how this turned out, and despite spending money on some components that I didn't use, would gladly do it again in order to learn about the internals of tube microphones. Maybe it's time to do an E LAM 251 build...
Delta Sigma
« Reply #388 on: October 27, 2020, 11:53:23 PM »
I haven't tried any other amp but since no one responded, I figured I'd chime in. If you want to stay close to the original circuit, build from the original schematic and try a solid state drop in replacement like the Phaedrus. Next closest would be the parallel 408As. The benefit to this amp is that the tubes are readily available and you avoid having to heat sink your big dropping resistor.
Try anything between 60M and 1G and see what you like. Not sure you'll hear any bass improvement when geting beyond a few 100 meg. I read somewhere (PRR on a guitar amp forum?) that the bigger your grid R the more hiss you get.
From what I've read, nothing will get you to a VF14. It also doesn't seem that hard to get a great mic based off the U47 design, whether it sounds like the original or not probably doesn't make any practical difference in the long run.
I also suspect that you could find a greater change in sound by swapping capsules and transformers before tubes, even when it comes to the legendary VF14.
« Reply #389 on: October 28, 2020, 10:50:09 AM »
Thank you Delta Sigma. There is also a substitute from Saturn sound if I am not mistaken. I guess my question was more if the changes in the circuit were made to improve upon the design or to compensate for the tube differences...or both. Since none of the essential components ( trafo, capsule, tube) are the same maybe Oliver fine tuned the circuitry around them. I just wanted to know, if possible, if those changes are utilitarian or for more faithful reproduction. What I do know for sure is that the design sounds awesome and definitely very close to the originals since here at the studio we have two of the original point to point Oliver’s kits. Thanks again for chiming in
Delta Sigma
« Reply #390 on: October 28, 2020, 01:06:48 PM »
If I remember correctly, Oliver liked 1G grid resistors and any redesign he did, used 1G:
http://www.tab-funkenwerk.org/articles-tech-documents-2/ami-microphone-schematic-archive/um57-schematics/
http://www.tab-funkenwerk.org/articles-tech-documents-2/ami-microphone-schematic-archive/cmv563-schematics/
Make sure you play with the grid resistor value. You may prefer a bigger value, 250M or so, over 60M.
The schematic looks drastically different because of the separate heater supply and deriving the bias from it.
« Reply #391 on: October 28, 2020, 05:10:07 PM »
Thanks, I’ll start from 100M for r1 and r2 and fine tune from there. I was able to find a few really nice NOS hydra and Siemens ( big square ones) MP 1uf caps that test/measure really well and for c1 I’ll start with an NOS ceramic like the very first ones. For that position I also have nos wima tff’s and Mullard mustard. Resistors will be carbon film except r1 and r2. This is a fun build for schizophrenic tweakers like me lol.
