ungifted
Re: diy-tubes.com - parts for DIY studio/guitar gear
« Reply #40 on: September 23, 2014, 04:02:16 PM »
Relay Bypass PCBs are in stock! Can be used with GSSL, Pultec EQ etc.
http://diy-tubes.com/bypass-pcb.html
http://diy-tubes.com - parts for guitar/studio gear
alexc
« Reply #41 on: September 27, 2014, 08:07:20 AM »
Thanks for the nice quality parts and good delivery service.
My order arrived well down here in lower Oz and will soon be passing some electrons.
Regards
AC
I ping therefore I am
ungifted
« Reply #42 on: October 01, 2014, 04:11:02 AM »
New bar knobs in stock. Bakelite, with two fixing screws. Very comfortable handle, can be used instead of chickenhead knobs.
« Reply #43 on: October 02, 2014, 02:08:54 PM »
Knobs arrived in the US today. Very satisfied. Will order the larger meters when they are back in stock
Adam
only got here by owning a soldering iron and bad life decisions.
ungifted
« Reply #44 on: October 02, 2014, 03:06:04 PM »
Many thanks for all for your kind words!
Meters are on its way, will be available soon.
ungifted
« Reply #45 on: October 09, 2014, 07:26:15 AM »
Mu-metal cans for OEP and Vigortronix transformers are in stock!
ungifted
« Reply #46 on: October 13, 2014, 12:22:27 PM »
VU meters (52mm) are back to stock!
http://diy-tubes.com/vu-meter-52mm.html
ungifted
« Reply #47 on: October 14, 2014, 04:10:17 PM »
Who was asking for 3mm turret boards?
http://diy-tubes.com/turret-board-3mm.html
usekgb
« Reply #48 on: October 14, 2014, 09:55:37 PM »
That was me.  Nice!
Zach Griffen Audio
EvilTone
ungifted
« Reply #49 on: October 16, 2014, 07:37:52 AM »
Rotary power switches in stock! If you decided to make Tube-Tech, Pultec or Gyraf clone you need them. :)
http://diy-tubes.com/rotary-power-switch.html
And some simple very good looking plastic Pilot Lights (if you don't want pay for metal ones).
http://diy-tubes.com/pilot-light-12v.html
ungifted
« Reply #50 on: October 18, 2014, 08:55:29 AM »
New arrivals.
Sifam/Elma style collet knobs - wing collet knobs and pointer collet knobs.
And some ICs and enclosures for guitar stompboxes.
anjing
« Reply #51 on: October 29, 2014, 07:33:50 PM »
I'm having problems checking out with paypal....
Rocinante
« Reply #52 on: October 30, 2014, 09:52:54 AM »
Just received my order here in the states, thanks. That was fast considering. Im definitely gonna grab more stuff soon.
Wish you the best of luck.
Dylan
If there's a harder way to do this, I haven't found it yet.
ungifted
« Reply #53 on: October 30, 2014, 04:29:45 PM »
Everything must be fine now. Just lifted my Paypal limits.
Please let me know if something doesn't work. I will check it.
Many thanks for bug reporting!
anjing
« Reply #54 on: October 30, 2014, 05:20:20 PM »
Order placed!
  About the davies 4107 knobs, i don't know if you can eventually do anything about it or not, i find the shaft whole too small for the standards 1/4 inch pots i use in all my projects. I just use a dremel to open the shaft whole, beside that the knobs are great, i'll be  using around 10 or them for my ez tube mixer. It gives me the look and feel of vintage knobs at a price i like!
Regards,
Pierre
OneRoomStudios
« Reply #55 on: October 31, 2014, 11:09:25 AM »
In the Single Bottle Preamp PCB description, it says the board can be used to build a " microphone preamplifier utilizing one 12AU7 (ECC82)," but I don't see that schematic in the manual (just "Tomato," "Real McTube," and "12AX7 Preamp"). Is there a schematic for this? What's it based on? Are there associated transformers?
Also, it would be great to have a kit like JLM's "go between" kit with phantom, pad, and polarity. You could add a variable hi-pass and make it really awesome.
ungifted
« Reply #56 on: October 31, 2014, 03:54:13 PM »
I meant NY one bottle pre when saying "mic preamp". Think about it as a simple cascade based on triodes with plate load.
First of all it's guitar/bass preamp. But you can add a transformer, use 12au7 - and you can try to build mic preamp.
I've thought about little kits like go between. I think we'll make something similar, but at a lower price. :)
ungifted
« Reply #57 on: November 08, 2014, 08:30:16 AM »
JFX Premium Metallized Polypropylene Film Capacitor (Axial) in stock!
Replace ERSE, Mundorf - MCAP MKP, Jantzen Audio, Mallory, BENNIC, SCR / SOLEN, Auricap, INTERTECHNIK, Ampohm audio series.
We have some nominals for interstage usage - 0.1u, 022u, 0,47u 400v rated for guitar/tube projects, and 2u2, 3u3, 4u7 (250v) - for mic preamps.
Has anyone tested them?
ungifted
« Reply #58 on: November 16, 2014, 04:38:40 PM »
More leds and diodes in stock. More knobs colors.
Relay bypass kit will be available soon.
ungifted
« Reply #59 on: November 23, 2014, 10:23:33 AM »
SIP sockets for GSSL project (THAT2180), toroidal trafo mount, FR4 and very good quality Samwha electrolytic capacitors in stock!
