Neve 1272 mic pre set and 2 X L31267 trannies
radiance
the Netherlands
EDIT:  see last post...
For sale: a collection of stuff intended for a neve mic / line pre amp thingy....I don''t have time for this project...
2 X vtb 2169 (slim version)
2 X VTB 9045
2 X L31267 (1 X st. Ives and 1 X Marinair...don't ask ;-))
2 X BA283  (populated with resistors and 2N3055...heatsink should probably be bigger)
2 X ELMA 3 deck, 24 position...1 should be made from a 2 deck and a 1 deck version ...all hardware is there...all used, so a lot of desoldering first...
1 very sturdy (NTP) case which houses a 24V PSU and which has a clean front panel
2 X universal input board (populated with resistors)
2 X 2n3055 (total of 4 with the ones already on the BA 283)
All this together (everything in the picture!) weights 3,5 kg and can be had for 599 euro + shipping and packaging coasts... This is not a beginners project!! If you know what this all is you know what it's worth...
Lets split this up a bit.
200 euro for:
2 X L31267 (1 X st. Ives and 1 X Marinair) see pic attached for the state of the pins....They both work and measure fine BTW!
400 euro for:
2 X VTB 9045
This last set can be used to build a 1272 mic pre for example....
