Rossi
Re: shaggy's mics
« Reply #40 on: August 27, 2014, 04:03:23 PM »
very nice metalwork, I'm impressed! It's good to see something different than the ever popular tube mic clone project.
There's nothing too special about the AKG C414 EB circuit(s). The silver 414 EB has a fairly simple darlington style circuit - whatever magic it possesses is due to its brass CK-12 capsule. The later black C414 EB P48 has a slightly more sophisticated circuit but omits the DC converter which also means that the circuit must do with very little current to keep the polarization voltage above 40 volts. The optimal C414 EB would be a combination of the two, i.e. the EB P48 circuit combined with the original EB's DC converter for 60 volts capsule polarization.
"I am not a number, I'm a free man!"
"Hahahahaaaaaa!!!!!"
Re: shaggy's mics
« Reply #41 on: August 27, 2014, 04:09:32 PM »
Thanks again for all the compliments, guys.
Now if someone would only go to work on a C-414EB PC board, sourcing of o/p transformers, etc... 8>]
cheers
Dave (shaggy)
What about C12a with 7586 nuvistor ? Such a great work deserve the best treatment ...
Ouau...
« Last Edit: August 27, 2014, 06:03:15 PM by lampas »
shaggy
Re: shaggy's mics
« Reply #42 on: August 27, 2014, 05:29:55 PM »
These are awesome. Did you cut the brass with ruler and scribe?
You mean mark-out with a scribe? Yes, or pencil lines over masking tape. To cut out the parts I use a metal-cutting bandsaw, or a jigsaw with a metal-cutting blade.
cheers
Dave (shaggy)
"Build stuff or get off my lawn!"
Dylan W
Re: shaggy's mics
« Reply #43 on: August 27, 2014, 06:33:32 PM »
Aha. I've also seen sheet metal cut by scribing a few times with a blade and then bending back and forth at the score.
I think your way is more efficient... both in terms of time and waste.
cheers
Dave (shaggy)
shaggy
Re: shaggy's mics
« Reply #44 on: August 27, 2014, 07:28:24 PM »
You mean mark-out with a scribe? Yes, or pencil lines over masking tape. To cut out the parts I use a bandsaw or jigsaw with a metal-cutting blade.
cheers
Dave (shaggy)
That technique only works with shim brass, i.e. sheet just a few thousandths of an inch thick. It's not ideal though, because it leaves a 'torn' edge. Metal shears or sturdy scissors work best on shim stock (but don't borrow your wife's scissors!) 8>]
For the 'square' bodies I use .050" or .062" thick brass,  usually roughed out on the bandsaw and then milled to size.
Dave (shaggy)
« Last Edit: November 28, 2014, 02:19:06 PM by shaggy »
shaggy
Re: shaggy's mics
« Reply #45 on: August 27, 2014, 08:31:31 PM »
Thanks, Rossi. I very much appreciate your comments.
"The optimal C414 EB would be a combination of ... the EB P48 circuit combined with the original EB's DC converter for 60 volts capsule polarization. ..."
Now, that sounds like a plan 8>]
cheers
Dave (shaggy)
Spencerleehorton
Re: shaggy's mics
« Reply #46 on: September 25, 2020, 04:08:50 PM »
Very inspirational, I've got a long way to go!! But definitely given me food for thought, lovely job shaggy.
Do you still make these?
website: www.mohawkstudios.co.uk
email: [email protected]
If it hisses its probably the wrong impedance!!!
Or a snake!!!
pucho812
Re: shaggy's mics
« Reply #47 on: September 25, 2020, 10:45:31 PM »
Look back at page 1. Very well done. I like the idea of the shock mount hooks right on the body. I bet they are fab.
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
