EmoRiot
Re: [BUILD] FET/500 Official Support Thread
« Reply #580 on: March 13, 2020, 09:25:09 PM »
Well... all was going well until...
I put together the Elements Copper pre last week and it was so fun that I ordered the FET/500 Rev A to do this week.
I started that a yesterday and today I got to the input transformer. The instructions said a plastic spacer would be in the box for the input transformer. When I didn't see it, I feared I might've lost it while taking initial stock of the parts. I set about fashioning my own spacer by cutting up some plastic from the T-pad's clear plastic shipping container. I mounted the transformer and then the next step is to mount the output transformer. And inside the baggie for the mounting hardware I find... oops... the plastic spacer!
Now at this point I probably should've just shrugged and though "oh well a spacer is a spacer." But instead I contemplated if my plastic macguyver version was inferior and went about desoldering the transformer.
That wasn't as easy as I hoped... 8 pins... lots of back and forth heating of the contacts, using a wick to soak up solder, and wiggling to slowly free the transformer from it's multi-soldered connections on the PCB.
I got it out with my PCB looking a bit worse for wear from flux, I think. I put the correct spacer on, reinserted, and resoldered.
Now... here's the concern. The transformer can be wiggled on the PCB. The pins on the underneath side don't seem to wiggle when I feel them, but the metal can on the top side definitely wiggles. That's got to be a problem, right? Something is up. Cold solder joints that have broken or has the transformer can itself come apart?
EmoRiot
« Reply #581 on: March 14, 2020, 03:43:42 PM »
Looking at a pic of the underneath side, I'm wondering if the wiggle I feel is just that gap visible between the hole of the outer housing and the inner iron. From this pic, it looks like the can would wiggle about as much as I'm feeling with it in place.
Maybe I'm okay?
EmoRiot
« Reply #582 on: March 14, 2020, 10:32:57 PM »
Maybe I'm okay?
I'll just update my two messages above for anyone else that comes through their build and feels the same wiggle. Everything turned out fine. I continued with the build, calibrated, fired it up, and it works beautifully. Hooray.
Hairball Audio
« Reply #583 on: March 17, 2020, 09:52:18 PM »
Ya the pins have a little "play".
Mike
Hairball Audio, LLC
DIY Parts and Kits
https://hairballaudio.com
Top secret stuff and upcoming releases:
http://instagram.com/Hairballaudio
http://facebook.com/hairballaudio
« Reply #584 on: March 25, 2020, 01:39:18 PM »
With all this quarantine time, I finally have some free time to look into an old issue. I built a FET500 rev D several months back and all went well, however there always has seemed to be an issue with unpleasant distortion at high levels of GR. Could this possible be an issue with the signal preamp linearity? At just a few dB of gain reduction with slow attack times, the ‘distortion’ or clipping quality isn’t heard, but when smashed it really becomes unpleasant. Is this normal or is there something I should check on the PCB?
aaronmc
« Reply #585 on: March 26, 2020, 11:53:42 AM »
Hi! I have a question about biasing my FET/500 Rev D units. I built 2 stereo matched units and went through the biasing procedure. I ran into a minor issue with step 2 on two of my units - the -10db light lights up at .384v instead of .388v.  I could not adjust V2 any further to get closer to .388. I figured .004v was close enough so I continued through the rest of the calibration process without any additional problems. This might have to do with the accuracy of my DMM reading a 1k signal.. not sure.
After completing the calibration, when I connect the units using the link cable (sending the same 1khz sine @ 775vac), one unit's meter (both VU and GR) seems to be off by 1db. This is happening on both stereo matched pairs. When I place the unit in bypass mode, one meter on each of the pairs shows -1db on the GR meter. When I remove the link cable the GR meter goes back to 0db. When not linked, the GR and VU meters on all units seem to track pretty closely with minor variances in GR. Any ideas what might be causing this?
« Last Edit: March 26, 2020, 12:03:55 PM by aaronmc »
Hairball Audio
« Reply #586 on: March 27, 2020, 06:04:56 PM »
Hard to say without looking/analyzing it, but yes at some point the GR FET distorts.  So if you "smash" it, it's going to distort.  You can try the input mod, that might help.
https://www.hairballaudio.com/fet-compressor-input-mod
Mike
Hairball Audio, LLC
DIY Parts and Kits
Hairball Audio
« Reply #587 on: March 27, 2020, 06:07:39 PM »
Not totally weird.  You could try the re-calibrating the QBias, but probably just some component tolerances stacking.
Hairball Audio, LLC
DIY Parts and Kits
