E escondite Member Joined Oct 1, 2014 Messages 11 Oct 4, 2014 #1 Hi! I need to make the cable between the power supply and the console. I have no information about connector's pinout for power supply. Could someone give me this info? Best!! Best!!
E echo zulu Active member Joined Jul 8, 2012 Messages 35 Oct 10, 2014 #2 There are two power supplies - Peripheral and Audio. Do you need to make cables for both? Also, MCI used two different versions of each cable. The serial number of your board will determine which versions you need.
